Will check the pressure relief valve first. Then do the Vaseline prep before spinning up without plugs / sparks.
Between my father and i we've had the car for nearly 36 years doing just 10,000 miles over that time and quite often its not been used or run for a few months and never seen this issue before. Its always had fresh oil typically 20/50 and filters every 2/3 years over that time so should I hope be in great condition internally? I will be interested to see the condition of the relief valve and pump gears to see if any damage that could have caused this. Keep you posted.
Group, please forgive me. I am overlong
as I do not write for professionals.
I deal with them but in a different way. I write for amateur Morgan owners like me and you.
As for why these things occur, Jeremy, I have no clue. Mechanics can be whimsical. Over the years, I see the
pressure relief valve sticking most often with storage. All things mechanical run more reliably with frequent usage. On the other hand, I find the
loss of prime happens most with oil changes mostly when non-Morgan mechanics change the oil ignoring the correct sequence our engines deeply require because of their oiling system.
And Jeremy, FWIW yours is not the game plan I would use
though you are ultimately the boss. It is very conservative. I have done both priming and the relief valve many times. Priming is always when I am swapping engines, which I used to do more than I changed my socks. And I have non-invasively (shown below) modified the oil pressure valve system on all my Plus 8s which requires its removal. Of course I have also done both many times by proxy. 95% of Plus 8s (1967-2000UK) are identical in this area to yours.
Luddite, check these simple instrtctions below please. I like taking advantage of your presence. Two aging minds are better than one.
THE PRESSURE RELIEF VALVE1. First and foremost, I cannot think of a way any intervention of yours can damage anything. That is for your assurance. The worst that can happen is you can negligently drop & lose forever a slippery component. Many of these are spring loaded, heavily oiled and gravity works in a drop's favour. Just be prepared. You also have the thimble shown on GoMoG, not one of the later ones. Keep it. All the internals for the pressure relief system are still sold inexpensively, either separately or as a kit...so losing anything will merely slow you down their delivery time. If you lose something, you can google it. The prices range more than 1000% for the same thing.
3. If the thimble does not pop out, it is stuck. Fish it out with a tool or a threaded long-enough bolt that fits into it and gives you enough purchase to convince it to leave its cozy home.
I once had a owner merely add another "thimble" which increased oil pressure intolerably. Trust me, whether it pops out (as it should) or sticks (as is also likely at the moment), it is there.
4. If it was stuck, clean it and reassemble, you could be good to go after running the car a bit with dizzy disconnected
without packing the oil pump with vaseline. After 30-60 seconds of that, receo0nnect the ignition and start her up. Always monitor from the driver's seat with your eyes on the oil pressure gauge. If you are mildly lucky, you will see no pressure at the gauge at first but then it will suddenly rise within 15-45 seconds. You see there is a reasonable hope that the pump will re-prime itself without vaseline.[/b] . If it doens't, stop turning the engine and pack the pump.
If you are lucky that entire fix will take 20 minutes..though us amateurs always take much longer the first time..which is NOT a bad thing. We are not on a professional's time clock, a BIG plus. Not packing the pump will save you an hour and be far less messy.
The only reason, at this stage, to remove the pump is to repair the inevitable wear on it.
https://www.gomog.com/allmorgan/oilpumpbase.html. At the moment, yours is the one on the left.
https://www.gomog.com/allmorgan/oilpumpbase.html That is not grave, just not great for oil pressure. 90% of all this V8's pumps are like that. But we should be happy, the later GEMS and Motronic (not used in Plus 8s) oil systems require the entire timing cover to be changed!!
Lorne
P.S. I would buy a new pressure relief valve spring along with the pump gasket just in case. I use a copper crush washer on the plug.
P/P/S I am very familiar with all this. I rely primarily on British V8 community lore. US lore of old can be ingenious but it is VERY old. With the UK tadpoles rather than the thimbles, I use a cute thingie from an performance Buick 215 supplier. It allows me to adjust my oil pressure with an Allen key on the road. ; )
![[Linked Image]](http://www.gomog.com/TEMP/OilPumpPressureRegulator.jpg)
