0 members (), 258 guests, and 102 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#841098 09/04/26 03:20 PM
Having unintentionally left my indicators going on a number of occasions, I am going to install the car builder buzzer, I have read other threads on this but am asking If any one has tapped into the cables coming out of the relay, would this be bad practice?
I have not yet identified the relay but assume it is close to the bulkhead and a short run to have the buzzer under the dash near the steering column
Black Rat
Black Rat
I tapped into the indicator wire where it came out of the light and fitted the buzzer high up behind the spare wheel, works for me.
Keith
2013 narrow bodied + 4 Ruby.
Similar to Keith I tapped into the two indicator feeds within the rear light loom that runs along the o/s inner wooden rear wheel arch. Buzzer located under carpet behind drivers seat.
As Keith says, much easier to access wiring in the rear loom (usually offside - access from spare wheel hole)
If you think about it, when you're driving your head is close to this area too for location of the buzzer
TBM Offline
If you're happy with a buzzer on all the time with the indicators, you can get two and three pin indicator relays with built in buzzers - just remove old and put in new.
I have a buzzer with a built in time delay so it only comes on after a certain number of flashes, and it silences when the brake pedal is used. That required a bit more wiring/splicing.
jbk Offline
The relays with the built in buzzers may not be loud enough (if for example you are using aeroscreens.)
If you carefully drill a small hole (1/8") in each face of the plastic relay case the volume will increase, if too loud tape up one hole at a time until it suits.
works for me, my wife says ime good at simple stuff!
1993 T16 +4 Lancia Blue.
