8 members (JMcL, Arwyn Williams, DPEvans, GrumpyPa, DaveW, JohnHarris, +8Rich, Burgundymog),
220
60
Posts837,257
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I have tested the Meguiars Mirror Glaze. It's a small bottle 8FL OZ. Photos are not edited, but two are squashed. ![[Linked Image]](https://www.tm-img.com/images/2026/04/09/55196011932_f6b8e8d6b3_o.jpg) One pass delivers this: ![[Linked Image]](https://www.tm-img.com/images/2026/04/09/55197055008_a658b0424a_o.jpg) ![[Linked Image]](https://www.tm-img.com/images/2026/04/09/55197055508_2625db649f_o.jpg)
3 members like this:
1854sailor, CooperMan, Luddite |
Posts: 879 Likes: 31
Posts: 879 Likes: 31 |
I've been a long time user of Meguiar's products, including among them #205, I have never been disappointed in their performance when used as directed. Exemplary result on a gorgeous car DaveW.
Bert & B1800 "Tis well enough to know how much to know; and when to know, not to know, too much."
1 member likes this:
DaveW |
Posts: 8,658 Likes: 487
Posts: 8,658 Likes: 487 |
Fitted a new Clevis Pin to the clutch pedal today, despite only slight wear and ridging it's surprising how much slop it adds to the travel
I think it's worth an annual check
Posts: 1,242 Likes: 30
Posts: 1,242 Likes: 30 |
Finally got around to removing old very rusty screws that hold the central part of the front wings on. Now done with A4 stainless screws & washers. ![[Linked Image]](https://tm-img.com/images/2026/04/10/IMG_0480.jpeg) ![[Linked Image]](https://tm-img.com/images/2026/04/10/IMG_0475.jpeg) Maybe worth checking as the running board tends to sag enough to loosen the rubber bead.
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
I got the AFR gauge wired, calibrated, and the O2 sensor installed in the exhaust. ![[Linked Image]](https://tm-img.com/images/2026/04/10/IMG_8960Crop.md.jpg)
"Maybe worth checking as the running board tends to sag enough to loosen the rubber bead."I strongly agree with your assessment Jon, no telling what manner of ugliness is hiding under there. Hope for you that the issue can be rectified without too great amount of time and/or expenditure.
Posts: 18 Likes: 1
Posts: 18 Likes: 1 |
I have tested the Meguiars Mirror Glaze. It's a small bottle 8FL OZ. Photos are not edited, but two are squashed. ![[Linked Image]](https://www.tm-img.com/images/2026/04/09/55196011932_f6b8e8d6b3_o.jpg) One pass delivers this: ![[Linked Image]](https://www.tm-img.com/images/2026/04/09/55197055008_a658b0424a_o.jpg) ![[Linked Image]](https://www.tm-img.com/images/2026/04/09/55197055508_2625db649f_o.jpg) The Meguiars Mirror Glaze says "for professional use only", why is that?
2012 4/4 75th Anniversary in Le Mans green
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Cooperman, I like your wheel arch liners, Any chance of sharing your install technique!
It's the neatest option I've seen. Martin.
BertL |
I strongly agree sewin! It's a great idea and shouldn't be very difficult or expensive to implement  Eagerly awaiting Cooperman's reply on the issue...
