0 members (),
180
74
Topics49,861
Posts837,542
Posts: 874 Likes: 157
Posts: 874 Likes: 157 |
I just called Mike's team at Shock Factory. They still offer the same shock absorbers I bought in 2018  The price is: €750 for the pair of front shock absorbers €480 for the pair of rear shock absorbers Note that the front shock absorbers are more expensive because they are designed as two mono-shocks  Here are the details they sent me  : Following our discussion, please find below the technical specifications for a 3-wheeler model year 2012 to 2017 (Euro 3 standard): FRONT: REF MN001 • Center-to-center distance of the front shock absorber pair: 311 mm • Upper and lower mounting points: Ø 12.7 x 38.2 mm • Shock absorber travel: 50 mm (including bump stop) • Adjustment knob position: lower part, facing rearward • Spring: 7 x 950 lbs/inch • Price: m-shock range €750 incl. VAT per pair REAR: REF TM001 • Center-to-center distance of the rear shock absorber pair: 341 mm • Upper and lower mounting points: Ø 12.7 x 38 mm • Shock absorber travel: 87 mm (including bump stop) • Adjustment knob position Lower section • Spring: 7x350 lbs/inch • Price: 2 Win range €480 incl. VAT per pair
A 3-wheeler model year 2018 to 2023 (Euro 4 standard): FRONT: REF MN002 • Center-to-center distance of the front shock absorber pair: 305 mm • Upper and lower mountings: Ø 12.7 x 38.2 mm • Shock absorber travel: 45 mm (including bump stop) • Adjustment knob position: lower section, facing rearward • Spring: 7x950 lbs/inch • Price: M-Shock range €750 incl. VAT per pair REAR: TMO002 • Center-to-center distance of the rear shock absorber pair: 320 mm • Upper and lower mountings: Ø 12.7 x 38 mm • Shock absorber travel: 72 mm (including stop) • Adjustment wheel position: lower part • Spring: 7 x 400 lbs/inch • Price: 2 Win Series €480 incl. VAT per pair
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Posts: 64 Likes: 9
Posts: 64 Likes: 9 |
Thanks for the detailed info... but this has confused me more.
I am so far unaware of Spax, ATR or Ohlin doing a different Shock depending on the year... to use a localism, pourquoi?
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
I think this difference relates to an increase in ride height that was required for Euro 4 compliance. Seem to recall Morgan moved the mounting points on the wishbones/trailing arms??
Clue is in the centre-to-centre dimensions and changes in travel...
No idea what has been done with the Ohlin/ATR options for Euro 3 vs 4 but am aware that many of the later cars were reverted to Euro 3 standard but don't know if this reversion included reverting the ride height.
1 member likes this:
PaulV |
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
No idea what has been done with the Ohlin/ATR options for Euro 3 vs 4 but am aware that many of the later cars were reverted to Euro 3 standard but don't know if this reversion included reverting the ride height. I don't think there were many EU4 cars built for the UK as using SVA for a EU3 spec car was available. In Europe they would have been EU4 and as you say had raised ride height. For the front it was done with different uprights and at the rear there are two lower mounting points which change the angle of the shock absorber and hence the ride height. As far as I know the shocks were the same dimensions for EU3 and EU4 but in typical MMC fashion they might have been different and they didn't tell anyone
Red Leader
PaulV |
That's exactly it, the first Euro 3 cars are lower than the Euro 4 ones...  it's as simple as that
Posts: 363 Likes: 37
Posts: 363 Likes: 37 |
The shocks for the rear of an EU4 car are different specifications (as detailed by Shock Factory) to EU3 even on the original MMC EU4 Spax fitment.
If you have an m3w still at Eu4 ride height then different rear shocks are needed - Ohlins are also able to supply a different rear shock absorber.
Rare to find EU4 ride height m3w's in UK but quite common to find them in EU. Out of 8 x m3w's here in workshop currently, 3 are at EU4 ride height.
