6 members (Arwyn Williams, Grumpy2, John Winn, Alistair, chanteclair, RichardV6), 301 guests, and 60 robots.
+8Rich 95
Posts837,266
Page 158 of 164 1 2 156 157 158 159 160 163 164
Black Rat
Black Rat
Originally Posted by 1854sailor
I put the wheels back on, got her back on the ground, filled the tank with fresh fuel and went to the grocery store. Life is good!
It's been a long road, now you need to find a long long road. Enjoy.
Keith
2013 narrow bodied + 4 Ruby.
1 member likes this: Luddite
Thank you! I missed the sunny, nearly 80° weather here a couple of weeks ago, but I'm hoping to get out tomorrow. It's predicted to be in the 60° range...
Thanks cooper man, very much appreciated and I really like your added support bracket method. especially the triangular examples!
Martin.
Following a recent engine oil and filter change, the bonnet was opened to check for any leaks. On reclosing the bonnet, the nearside rear catch knob literally came off in my hand! Don’t know if the bonnet knobs are OE or aftermarket items but the catches have never required gorilla strength to release, so this came as a surprise.
The threaded extension to the catch knob had sheared off at the outer face of the sliding plate and the inner portion of the thread with hex nut remained in the sliding plate. Access to release the catch from inside the bonnet looked to be challenging.
The adopted solution below.
The threaded portion remaining inside the sliding plate was drilled out from the outside and ultimately fell to the running board, complete with nut. The thread was confirmed as M6.
The knob was drilled to 12mm depth, starting at 2.5mm dia and working incrementally up to 5mm dia. The swarf revealed the material to be brass.
An M6 thread was then cut to full depth.
A 25mm length of stainless M6 threadbar was screwed into the newly cut hole, sealed with threadlocker and tightened.
This assembly was then screwed into the sliding plate to enable the bonnet catch to be released. A washer and stainless nyloc nut clamp the knob to the sliding plate, thus making a connection somewhat stronger than the previous arrangement. Job done.
Now that one has failed, more are likely to follow. A winter task will be to strengthen the remaining knobs in like manner.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
4 members like this: 1854sailor, RichardV6, +8Rich, Graham, G4FUJ
Well done Chris
Good solution Chris thumbs
Online NoMood
Great job Chris thumbs. I was surprised the remaining stub couldn't have been removed by turning original locknut. Is the sliding catch plate threaded itself or just 6mm clearance thinking
Photo below taken whilst making my bonnet stays shows reasonable access to catch release locknut.
The sliding plate was threaded. Access to the locknut somewhat fraught when the bonnet is closed sherlock
Chris
Online NoMood
Are yes wink forgot about that blush. Good to know sliding catch is threaded though thumbs
TBM Offline
Just for info, the older Mogs have a 1/4 BSF thread on the bonnet knobs, just to be really awkward!
