1 members (Montegue), 354 guests, and 49 robots.
+8Rich 93
Posts837,277
RussJ Offline OP
Good evening.
Must be in here but, sorry, I cannot find it.
Where are the adjusters for the cable on the hood release on a plus 6 as cable appears stretched?
Thks
Assuming it's the same as Trads, remove the spare wheel and you'll find you can trace it from the latch holes you can see in the rear panel
Image here if same as Classics which I believe it is. You won't have a spare wheel on a Plus Six but hopefully louvred removable panel.
you need to remove the rear upright board with the speakers. 4 allend screw plus a pallet knife to ease out the plastic plugs in the wood.
Here are some pics of getting to the mechanism. I was fitting speakers so didn't play with it.
RussJ Offline OP
Thks much appreciated
