Posts837,276
Posts: 33 Likes: 14
Posts: 33 Likes: 14 |
Hello everyone, seeking pearls of wisdom.
Sidescreens have been on for a few days and whilst the drivers side is fine, the n/s is annoying me ! As a lengthy road trip to the Alps beckons I thought I would install them to ensure everything was “present and correct”.
In spite of being correctly positioned and being tightly secured, the leading edge of said n/s sidescreen insists on “vibrating” against the windscreen edge, resulting in an intensely irritating rattle. So before I resort to throwing said sidescreen into the nearest river, I wondered if anyone else had experienced this “unique and lovable foible” and found a cure/fix please ?
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Think I know where you are coming from. Could you post a few pictures or if like me that seems an impossibility PM me here and I'll give you my contact details an we can sort it from there!
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Before tossing them into the Cam, just see if these seals will fit your car.
Roger 2011 Plus 4
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
The front sidescreen bracket can be carefully bent slightly off the car, in a vice. It doesn't need much.
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
I've found firm but gentle pressure over the straight edge of a wooden bench top works Chris. This along the line of aluminium frame bottom and lower part that secured to door top. The aim is to ensure the sidescreen frame engages with windscreen frame U shaped side rubber and top edge rests firmly against top edge of windscreen as door reaches fully shut position. If side screen frame doesn't touch firmly at top more bend is required.
Posts: 829 Likes: 22
Posts: 829 Likes: 22 |
Bin them. Last had mine on the +8 in 1987.
1980 +8 Blue And a few others ---------------- Stephen
Posts: 1,391 Likes: 257
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,391 Likes: 257 |
Bin them. Last had mine on the +8 in 1987. 😂😂😂 Brilliant. What mileage do you do...?? 🇬🇧🇬🇧
Posts: 33 Likes: 14
Thank you all - extremely useful advice that will be explored in full.
Posts: 32 |
Had a similar problem which after 3 months of faffing around ,deposited the car with brands hatch morgan and let len sort it out..with a dot punch methinks no problem since
