11 members (DJC, JohnHarris, +8Rich, John V6, Arwyn Williams, DCH, DPEvans, Stephen888, DickJ, CooperMan, Farmershands), 343 guests, and 59 robots.
Posts837,255
#842496 01/05/26 12:53 PM
Hello everyone, seeking pearls of wisdom.
Sidescreens have been on for a few days and whilst the drivers side is fine, the n/s is annoying me ! As a lengthy road trip to the Alps beckons I thought I would install them to ensure everything was “present and correct”.
In spite of being correctly positioned and being tightly secured, the leading edge of said n/s sidescreen insists on “vibrating” against the windscreen edge, resulting in an intensely irritating rattle. So before I resort to throwing said sidescreen into the nearest river, I wondered if anyone else had experienced this “unique and lovable foible” and found a cure/fix please ?
Think I know where you are coming from. Could you post a few pictures or if like me that seems an impossibility PM me here and I'll give you my contact details an we can sort it from there!
Rog Offline
Before tossing them into the Cam, just see if these seals will fit your car.
Roger
The front sidescreen bracket can be carefully bent slightly off the car, in a vice. It doesn't need much.
I've found firm but gentle pressure over the straight edge of a wooden bench top works Chris. This along the line of aluminium frame bottom and lower part that secured to door top. The aim is to ensure the sidescreen frame engages with windscreen frame U shaped side rubber and top edge rests firmly against top edge of windscreen as door reaches fully shut position. If side screen frame doesn't touch firmly at top more bend is required.
Bin them. Last had mine on the +8 in 1987.
1980 +8 Blue
And a few others
Stephen
Stephen888 #842599 02/05/26 03:36 PM
formerly known as Hugh Jorgan
Brilliant.
What mileage do you do...??
Thank you all - extremely useful advice that will be explored in full.
Had a similar problem which after 3 months of faffing around ,deposited the car with brands hatch morgan and let len sort it out..with a dot punch methinks no problem since
