8 members (JohnHarris, Ian Wegg, DJC, +8Rich, John V6, Arwyn Williams, DCH, DPEvans),
340
67
Posts837,255
Posts: 37 Likes: 6
Posts: 37 Likes: 6 |
One other thing to check is how tight the brackets are to the door! On mine I found the ns screen rattled like nothing on earth, and discovered the bracket with the knurled wheel was loose. No matter how you tightened the knob it became loose from the door. I tried pipe tape on the screws which lasted 300 miles. Found a solution on Amazon - An idea using metal strips to insert into the screw holes and then tighten the screws! AMAZING! Also bending the sidescreen front bracket using the line that you will find with a pair of pliers carefully works wonders. Then use some DIY internal door draft excluder and bingo! No rattles and no water coming in!
Robin
2005 Plus 4 1976 Plus 8 prev 1972 4/4 prev 1959 Series 2 prev
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Posts: 12,255 Likes: 317
Posts: 12,255 Likes: 317 |
Yep, I agree. I've had a set on my car for years and they work very well.
