4 members (B3MOG, Image, sbarracl, JohnHarris), 193 guests, and 47 robots.
Posts837,249
One other thing to check is how tight the brackets are to the door! On mine I found the ns screen rattled like nothing on earth, and discovered the bracket with the knurled wheel was loose. No matter how you tightened the knob it became loose from the door. I tried pipe tape on the screws which lasted 300 miles. Found a solution on Amazon - An idea using metal strips to insert into the screw holes and then tighten the screws! AMAZING! Also bending the sidescreen front bracket using the line that you will find with a pair of pliers carefully works wonders. Then use some DIY internal door draft excluder and bingo! No rattles and no water coming in!
Robin
2005 Plus 4
1976 Plus 8 prev
1972 4/4 prev
1959 Series 2 prev
TBM Offline
TBM #848433 20/08/26 07:20 AM
Originally Posted by TBM
Yep, I agree. I've had a set on my car for years and they work very well.
