Morgan Aero 8
7 members (Fuel.inj, GrumpyPa, JohnHarris, RichardV6, TBM, Hamwich, DCH), 197 guests, and 94 robots.
+8Rich 77
Topics49,870
Posts837,669
Rudolf
#842917 08/05/26 02:29 AM
kiwi100 Offline OP
Can any member or business help with a source of Aero 8 series 1 or 2, front end steering rod rose joints. These have a 10mm bolt through the rose but a UNF thread to the rod end.
Try Melvyn Rutter, BHM and Williams as first points of contact as all will have customers with the need for these sacrificial joints.
JMD Offline
https://www.hendersonbearings.co.uk/rod-end-bearings.html
These guys have a huge range with various quality levels
Online NoMood
somewhere on here Peter Jenks put a post about this. If I remeber correctly they are very special & he paid a lot of money to replace them.
As a sporty upgrade I fitted Aldon Automotive rose jointed arms in place of the rubber bushed and worn out arms on my Frog Eye sprite, many decades back.... The rose joints wore out in jig time, compared to the cheaper arms with rubber bushings...
At the risk of teaching egg sucking, IF replacement original design rose joints might be difficult to find, I suspect/hope that if you can not find a direct replacement, there will be an engineering shop that can modify an old style steering joint/track rod end to fit.
It seems over the years Morgan have ever made use of parts found in other cars and folk like Melvyn Rutter, and Lorne at GoMoG.com have spent inordinate amounts of time in research to find original suppliers..
Sorry to ramble on, but hope this helps if you might still be looking for the part(s) you require to keep your wonderful Morgan running..
Online NoMood
This Aero S2 parts book screenshot may help.
Note the locknut for TRE is shown as M14. The diameter and 1.5mm pitch is close but not a perfect match to 9/16" UNF thinking
1 member likes this: Luddite
kiwi100 Offline OP
Thank you for all your informative answers. We will look into them all. It's great to have such helpful mates on TM.
Happy Miles.
