0 members (), 238 guests, and 29 robots.
+8Rich 89
Topics49,841
Posts837,323
Christoph
John V6 Offline OP
My side screen panels are getting scratched.
Does anyone know of a product to remove the scratches before I change them.
Renovo do a plastic polish, which is ok.
http://www.renovointernational.com/products/p_wpolish.php
John V6 Offline OP
Thanks I have placed my order.
I have spare perspex screens as I got 4 cut 5 years ago but will try this first.
Or you can try Brasso - it works fine, but needs some ellbow grease.
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
As said Brasso is the stuff, and a hand held wizzy thing (dremel etc) makes the job a lot easier.
Does anyone know what adhesive is used to glue on the finger catch to slide the rear window. I think they would be pretty easy to make.
I was led to believe that the finger catch is not glued on, but it is a hole cut through the perspex through which the "catch" snugly fits!
Methylene Chloride is a liquid which glues plexiglas. The glue should be available at hardware stores that handle plexiglas. A syringe or brush should be used to apply.
There is a youtube on how to glue plexiglas.
I have the same problem with my sliders. Two of the tabs are missing so I will have to glue some on. No holes in my plexi/perspex.
'67 +4 tourer - broken white - RHD
No holes in mine, a tab is stuck on each rear window, to slide it back with your fingers.
I don't know how the stuff Vitruvius recommends works. I used a common glue for hard plastic (UHU). The trick was to spread it on the tab very evenly because every irregularity (?) is clearly visible through the plexiglass.
1967 4/4 1500 Comp.
