6 members (esse16, Ritchie B, Bitsobrits, Tony Quinn, IcePack, Rog G), 285 guests, and 107 robots.
+8Rich 77
Topics49,868
Posts837,642
Moggo
#843569 18/05/26 06:18 PM
Might any of you knowledgeable members be able to tell me what the recommended size battery is for a 2004 (last of the rover engined) Plus 8?
thanks
I should add that it's under the bonnet, not at the rear.
Under bonnet location limits battery height which also leaves capacity sub optimal. The Odyssey PC925 will fit though and have a good reputation.
Originally Posted by JohnPlus8
Might any of you knowledgeable members be able to tell me what the recommended size battery is for a 2004 (last of the rover engined) Plus 8? thanks
John, Expensive batteries and unhappy placements in the car don't help your mogging or reliability. (There is a cute Morgan story about your era's placement but I will keep this short as I can.)
In short I gave up buying exotica and I use the traditional battery placement at the axle. The stock placement (unless it has been changed) rightly bothered the late Colin Jones who used to post here under the name SpannerJuggler. The two of us were very close once, I have hangover memories to prove it. smile
Colin, with your car, designed a proper battery placement. Peter Mulberry agreed and sold it as a kit with Colin, but that era is long gone. I co'opted by them as I used something similar early that year. I posted their article on GoMoG. Which I will re-post now just as they sent it to me. https://www.gomog.com/allmorgan/batterytrayinstallation.html It is really quite easy to have made..by anyone or yourself. I use mine with hinges the tray swivels down and drops the battery on the ground. All the holes in your suspension hoop you need are already drilled. Take a look. This means you can buy any battery you want! I choose the easiest battery to find in the area I am mogging. That will inevitably save you precious Morgan times and LOTS of money. I prefer batteries with amperage over 900 cranking amps. Manufacturers recommendsbetween 600 and 800 Cold Cranking Amps (CCA).. You can find any size you wish with the table's indicated type number.https://www.gomog.com/allmorgan/CarBatterySizes&BatteryCutoffSwitches.html#NUMBERS For example the Odyessy 925 Battery code number BCI) is a 56. Others will suit your car as well or better as Colin found out and I found out. About 50 quid is what you should be paying rather than 200 and you will have a better balanced car and less risk of a ruined day.
You can use the newly emptied space on the bulkhead for picnic sandwiches or tools, like I do.
Lorne
I had the Odyssey PC925 on my 2004 Plus8. There was one on when bought and it started to fail after 9 + years so my guess at least 10 years old. A Ctech conditioner was used regularly. No starting problems at all. I decided to replace with similar as a pet hate is failing batteries.
I have an Odyssey PC 925 in my 2003 Plus 8. Twelve years old and still fine. I am thinking about replacing it soon based on age. I do keep it on a desulfation maintainer. I feel it is worth the extra money for long life.
Dave White
2003 Plus 8
I got 13 years from my original Roadster battery, but it failed without warning, but in the garage at home.
DaveW #843615 19/05/26 09:42 PM
How lucky! https://www.rac.co.uk/drive/advice/...ies-last/#how-long-do-car-batteries-last
I have had incidents like that. I think Morgans love the owners that take of them.
L.
Odyssey PC925 in our 2003 Plus 8 - replaced one that was almost 15 years old. Kept on a Noco Genius 5 battery charger/conditioner.
Ken
Current
2003 +8 35th Anniv. Model
2014 Porsche Boxster GTS
Previous
1996 Jaguar XJS Celebration
I have the Odyssey PC925 mounted on its side in the original place behind the driver , it was too tall to sit upright.
99 plus 8 indigo
