7 members (TBM, GrumpyPa, Morganmike, Alistair, DPEvans, ChrisMorgan, piquet), 290 guests, and 27 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,331
Christoph
Hi All
I've just reassembled my front suspension after replacing KPs, bushes, main springs, wheel bearings, brake pads, braided brake hoses, new bearings in Mulfab steering bearings etc etc. Great thanks to Arwyn Williams for pressing-in and reaming the bushes and pressing in new wheel bearing races.
A simple question. On a 1996 +4, is it necessary to to aquire and fit the brake pad retaining pins which are fitted on some trad cars from new (I don't know if they always were), rather than using the split pins which came with the pads and which are the same as were previously fitted on my car? It will cost me £25, including post from Gammon and Baker.
Thanks in anticipation to anyone who knows the answer.
David Stuart
Mogdavid
I think that the dumbell pins came along in around 2006 or maybe a little later, when Morgan changed from Lockheed to Caparo callipers. So I reckon your split pins were the standard fitment for the callipers in 1996 and do the job.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
The later calipers are alloy which may be why they use dumbell pins and spring clips
Your calipers will be cast iron David, so stick with split pins as per OE
Hi gents
Thank you.
Those answers suit me very well !!!
Not having compared like for like, I think it possible the holes would be slightly bigger to allow use of the dumbell pins.
Cheers
David Stuart
Mogdavid
