1 members (TBM), 198 guests, and 66 robots.
+8Rich 76
Luddite 50
Hacked email account
by +8Rich - 08/09/26 01:47 PM
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
Topics49,889
Posts837,896
Morganzeal, Pablo
#843660 20/05/26 08:48 PM
moggin Offline OP
I am attaching a Librands luggage rack (with sidescreen space) to my new 2025 plus four. At least I'm trying to. It's a 5 wheel car. Does the original "lipped" disc go over or under the rack? Either way, I can't turn the T-bar down enough to tighten the wheel/disc/T-bar package. It all just rattles. Do I need to grease the threads or even add more washers? There's one washer already but still leaves a space.
You can't beat a man at his own game.
I have a Librands rack on my MY23 car with spare wheel. When in place the rack bar just touches/rests against the tyre.
Just checked and the round disc fits into the spare then the rack plate on top.
One awkward thing is lining it all up so the T-bar goes into the screw base. I had to use spacing washers on the bottom mounts to get good alignment of the rack plate hole with the threaded mount hole in the wheel well. A small left-right adjustment. Slightly longer bolts needed but not much.
The spare tends to slide downwards so I use a a padded insert between the tyre and rear panel to keep it stable while screwing the T-bar in. The plastic panel the wheel sits on is smooth so the wheel can slip.
I suspect this mis-alignment might be why your rattling occurs due to the T-bar not engaging into the threaded hole? The T-bar needs to be aligned correctly or the threads don't engage cleanly and can get tight/damaged. The dropping wheel can pull it out of alignment.
Try screwing the T-bar in without the wheel and rack in place to check it goes in ok and a bit of lube will help. Also put some white/pale tape/paint round the hole for the bar to help see it with the wheel in place so it can be centred correctly. This is where the padded insert helps.
If the thread seems tight /damaged then get a tap to clean it up. From memory it might be a 1/2" BSW thread.
I
ITP Offline
I
Having spent about twenty minutes trying to re attach my spare wheel on my CX I have made a small funnel type device which makes it easier to locate the hole for the spigot. Try as I might I cannot get the system to accept my pictures of it. I could send the image by normal email if I have an address.
ITP
4/4 80th Edition (Sold)
Plus 4 X 2022
I
ITP Offline
I
Imges
ITP
Plus 4 X 2022
I
ITP Offline
I
Pictures now available in gallery.
ITP
Plus 4 X 2022
