Posts837,248
Posts: 651 Likes: 12
Posts: 651 Likes: 12 |
I have read horror stories about tha duratec plastic intake manifold where the swirl flaps come loose and are sucked into the engine with catastrophic consequences. Does anyone know the life expectancy of these parts in terms of years or milage?
Greetings, Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
I've got 48k on mine in 13 years no problem.
Posts: 8,655 Likes: 407
Posts: 8,655 Likes: 407 |
I wouldn't worry too much Harald. Whilst it's not unknown for Duratecs to swallow swirl flaps the usual gradual failure is their bearings which lead to rattling and vacuum leaks rather than immediate engine destruction.
Posts: 2,084 Likes: 69
Posts: 2,084 Likes: 69 |
I understand that very early ones were vulnerable but Ford brought out several improvements up to about 2006. I am now at 58k+ miles and 15 years and still ok.
I wouldn't worry too much Harald. Whilst it's not unknown for Duratecs to swallow swirl flaps the usual gradual failure is their bearings which lead to rattling and vacuum leaks rather than immediate engine destruction. I understand that very early ones were vulnerable but Ford brought out several improvements up to about 2006. I am now at 58k+ miles and 15 years and still ok. Thank you for the replies. My car is a 2008 model at almost 80000 km. I'll keep my ears open for new rattle sounds  but eventually I may convince myself and  that a metal plenum is a necessary maintenance step.
Posts: 23 |
I seem to remember some time ago there was a thread that dealt with the removal of the swirl flaps and linkage. I believe it had the added benefit of slightly improved performance?
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Yes you'll hear them well before they fail and generally the shaft will wear through first so it's almost a fail safe system. Don't mess around when you suspect they might fail just strip them out and leave it at that!
