I'm doing a diagnostic run through on my GDI.
I've fitted some NGK Laser Iridium plugs. ILTR6A-8G.
For the record, the fuel pressure sensor, which is located front nearside ahead of the inlet manifold, is part number 9F972EA 11517 N004T
This is a threaded sensor.
The coolant sensor, which is on the rear offside corner of the block, with a shiny insulated cable feed, is part number 7C1112A648AC 0216A F903A
This is a push in sensor, secured with a C clip. Standard Ford part.
However, after enquiring, this is not listed on the parts list, or the Morgan Factory dealer order screen. So as usual, it needs investigating!
