Anyone know the specific process to remove the key cylinder from the steering column? I have a new cylinder. I looked at existing situation. There’s 2 “ tabs on stalk below and under the cylinder. There’s a “ threaded hole “on steering column , on top side of cylinder. And then there’s a weird “ roll pin “ looking hole as well , almost looks like it has a triangular pin in it / hole . Please advise if you have experience with this dilemma. Ha
What’s in the threaded hole ? Could not get an Allen key to fit anything in that hole . Also do I need to even remove the “ roll pin “ , it may not be something that needs to be removed . I just have no idea . And zero info is available on web Tx
