1 members (Plus Four Guy), 329 guests, and 52 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
E
E
Final remarks from me
Ford Specs MC2C913A and B were produced pre 2000 and required a light weight oil for better fuel consumption and did not have a lot of oil shear additives etc.
Ford spec MC2C913C around say 2006, I cannot get a firm date at the moment not only required a light oil for good fuel economy but additives to improve engine cleaning, sludge reduction, engine wear reduction and soot thickening reduction.
Ford Spec MC2C913D in 2012 added further improvements to oxidation thickening.
Ford Spec MC2C913D is advised for the Sigma engine, the expert engineer friend of Heinz from the US has not checked what the current Ford Oil Specification for that engine requires with regards to additives and his comments are way off the mark.
Eddie, what spec would you recommend for the 3.7 Roadsters, as there's scant info from MMC and the oil filler cap just says 5w-30 semi synth, which I feel is wrong
Heinz Offline OP
I would also be interested in the answer. In my estimation, it is as follows.
You have an American engine. The Americans don't know anything about oil. They pour what's on the shelf right now. The people at Ford have no idea what they are doing. Conclusion is, your 3.7 runs with everything at hand...smoothly. smile
Does anyone know details about the rare fiats?
What engine Oil is recommended for the 1995ccm Fiat engine?
Yes mine is one of them...
Many Thanks
Miklos
1973 2CV AK400 Ralley
1985 plus 4 four seater
1992 Peraves ecomobil
bicycles (pedersen to recumbent)
Heinz Offline OP
Miklos, are you sure about 1995? I thought it was 1985.
Sorry you are claiming the ccm not the year. I have found this.
https://www.bestpartstore.co.uk/7889142-liqui-moly-engine-oil
Just click on Fiat below. It is an example you can of course use every brand with oil of the same specs.
2013 M3W
2019 Roadster
Heinz Offline OP
I know this excellent American oil page and several articles. But in this article he refers only to quality differences of different brands. Differences in viscosity class or additive and HTHS values are not questioned here.
Thanks very much!
The tesl article is quite interesting as well - that´s why I never had oil related problems so far....
And I thought it was because of my accuracy with oil;)
Miklos
Heinz Offline OP
Originally Posted By twotribes
Heinz, does the answer from your friend also take into account that - in the TI VCT / Sigma engine - the oil has another 'job' to do in that the engine oil pressure also operates the camshaft timing through oil-fed hydraulic actuators.
I would be wary of changing any characteristics of the oil which could impact this cam timing mechanism - unless your friend has factored in this unique feature of the Sigma engine.
Yes there is an influence on the VCT action regarding the oil viscosity. With focus on the viscosity specification, the friends friend who works at Ford USA writes:
..."Too thin is a problem with VCT actuation actually. Oil too thin may not have enough pressure to allow the VCT to actuate properly when it gets hot. It thins out when it is hot and the pump can't create as much oil pressure. Too thick doesn't flow well either. Oil pressure is meaningless without flow. Too thin is a problem with VCT actuation actually. I bet it does work better with 5W40"...
He does not say that a 5W30 is a too thin oil. But you can imagine that e.g. a 5W20 if it is hot and the engine is always used hard it can crack the molecular chain which can result in a sort of "5W10" after a period of time - even faster so if the oil gets its viscosity by a heavier use of additives than a good basic oil. And that would be obviously too thin for a proper working VCT.
(BTW the fact that Ford prefers oils with lowered HTHS values regardless the general hot temp viscosity value (A5 vs. A3 in European terms) should not have any influence to the work of the actuators of the VCT because I think that at the VCT the oil is not so hot to its limits as e.g. at the piston rings).
Now regarding the engine (not only the VCT) it should not harm the Sigma engine to use a higher grade viscosity. Ford recommends normally a 5W20 or 5W30 for the 2.3 Eco boost resp. the 5.0 V8 engines you can download the 2018 service manual in pdf. Ford recommends for track use a Motorcraft (Ford) 5W50 for both of this engines and also for the Shelby Mustang (different manual). You may need slightly more fuel but the engine has a better protection. Thats why Ford recommends it to go up in viscosity when driving hard.
BTW the above mentioned engines have the same VCT mechanism as the 4/4 Sigma engine has.
I like to push my engine and I like high revving when driving the B-roads in a sporty way so I have changed my engine oil to a fully synthetic 5W40 last weekend just to test it.
My first impression is that the engine is less loud (good or bad) and above 5000 rpm the engine is a very small bit more unwillingly revving. After 500 km this unwillingness is almost gone or I am used to it now.
But the big advantage is, and this is not self fulfilling prophecy, that the engine feels much better from 2000 rpm on which I thing it could have really to do with the better working VCT mechanism due to the higher viscosity of the W40 oil. Now the engine feels more so as if there were no VCT at all but a bit more capacity, in other words much more seamless and responsive at any point of the rev band and even significantly more powerful between 3000 rpm and 5000 rpm.
My oil pressure gauge is almost meaningless and the following values cannot be right but I can see a difference. With the thinner oil it showed 1 only when cold and after one hour mostly 0 and maximum 0.5 only when revving very high. With 5W40 it shows around 1,2 when cold and 0.5 when hot and running medium revs up to 1 when revving high. At idle at a red light it goes down to 0 again when hot.
E
E
Sorry guys I am not recommending oils here. Ford recommend a 5W/30 A5/B5 engine oil for that 1.6 engine in question and I was advising that the guy Heinz was talking to had not kept up with Ford Oil Specs and was giving him poor advice. I would check the Morris Oils website for a recomendation for your cars.
