2 members (JoeSpeetjens, Bitsobrits), 253 guests, and 103 robots.
Topics49,847
Posts837,389
#844905 12/06/26 05:47 PM
riri Offline OP
Underneath the Morgan, the bolts protrude beyond the nuts.
Would it be a sacrilege to cut these bolts off flush with the nuts?
Greatings from germany, +8 1997 3,9 l blue
riri #844907 12/06/26 05:57 PM
I do all mine, but leave one thread clear of the nut.
riri #844909 12/06/26 06:04 PM
You need a bit clear to thread it on easily. Also is you cut them run a nut below the cut so you can recut the thread.
riri #844911 12/06/26 06:19 PM
riri Offline OP
Do you use an angle grinder—which generates heat—or a handsaw?
riri #844915 12/06/26 06:46 PM
I use a grinder with a cutting disk not a grinding disk. Remember to wear goggles.
riri #844916 12/06/26 06:50 PM
Don't forget to dob the cut ends with some anti-rust wax like Waxoil
riri #844924 12/06/26 09:57 PM
or replace with stainless.
riri #844927 13/06/26 05:26 AM
Seconded if you have the option
riri #844935 13/06/26 07:02 AM
Thirded 🙂 .... when I did my resto I replaced everything non safety-related with stainless (with nyloc nuts) ... just brakes and suspension mountings with tensile steel. TBH you could probably swap those as well, but it's an old racing thing that you don't use stainless in suspension, steering or brakes and I just stick with it ... an 8.8 bolt is the same as an old 'S' grade as near as makes no odds for road use. I use a tiny smear of copper grease on assembly as stainless can gall if provoked .... beats struggling with rusty nuts and bolts somewhere down the line.
riri #844938 13/06/26 08:26 AM
Boltworld does some very good selection packs
