Has anybody come up with a fixed drip tray for a trad Plus 8? Not sure where it’s coming from but curing it looks like a major job and so better to live with it and find a way of catching the drips. It’s not a problem in the garage as I have an old boot liner to slide under the car but I can’t be taking this everywhere! A common issue so somebody must have a solution please.
😂😂😂 Sorta like diaper than encloses the entire engine area? Love it. You are more honest than most merely to ask the question. The Rover Plus 8 is a disgrace in this area.
I was like you 35 years ago. A leaky engine had to be a sign the owner had failed. I lived remotely in Quebec. No contact with another Plus 8 owner for the first 4 years of ownership and car care. Nothing to compare. In that time, I felt I had to cure the mess. I did so with determination.
I am self-taught with this famous (infamous?) engine block. Don't know much or care about others. I have a theory on the disgraceful leaking..mostly fact and some observation. You see, this was a space-age block when it was first experimentally cast in the very late 1950s. New material, aluminum, much more porous and chemically reactive than cast iron. All sorts of issues. Among these was a reputation for wholesale leaking, and this perception was carried on until this day,
handed from one expert to others, generation after generation. I will not mention names, but I have seen engines arrive fresh from the most legendary that mark their place at installation. Experts have no solution. I have never even see a write-up on it.
But I did find out that Rover/LR worked to stop the leaking by modifying the engine, gaskets, components, use of silicone (aka Hylomar) in hope of making the engine run respectably. These things are ignored by the experts. Experts don't like change. The stick to what they were taught 30 years ago. So after a bit of their servicing, even the newer engines become a mess again.
All my own of these V8 engines (I have 5) are
bone dry and use no diaper. I have helped with countless others. I do do my own engine work, down to the smallest detail. I claim extensive formal training in Law and Economics and no mechanics whatsover.
I can walk you through how to achieve a leakless V8 depending on what of the many of these V8 engine variants you have. They all take different tricks. I can do so with you privately, unless there are other Plus 8ers here who yearn for a non-filthy engine and bay.
Lorne
1984 Plus 8 3.5
1990 Plus 8 3.5 & 4.6
2002 Plus 8 Special, 3.5 & 4.8
P.S. I have noted 10+ leaking areas most often with some failing simultaneously making diagnistics complex. BTW, the improper installation (there are tricks to it) of the valley gasket, and which type you use (tin or composite) is can cause either an oil or coolant leak or both. It is not the first area that comes to mind.
