0 members (),
329
79
Topics49,870
Posts837,668
Posts: 1,400 Likes: 258
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,400 Likes: 258 |
Has anyone got a wiring diagram for an 07, 1.8 Duratec 4/4..?? Specifically the dashboard and indicators/hazzards. The factory donβt have oneβ¦β¦!π€·πΌββοΈπ€¦π»ββοΈ
π¬π§π¬π§
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
Julian, if you click on this link you should get the option to download a pdf copy of the Classics 2006 - 2014 parts catalogue. At the end of this you will find a series of wiring schematics. It's for you to choose which is appropriate as there were many changes during that time window. Unfortunately none cover the specifics of the infamous PCB in all it's variants. Rog of this parish is the one who has delved deepest in this area to the extent he replaced his PCB with easily replaceable common relays.
1 member likes this:
xc68anc |
Thanks for that Richard. I think we may have some of them...... amazingly they're not detailed enough, they show black lines but not what the black lines are...... I seem to remember a thread about the pcb....... where will I find it...????
π¬π§π¬π§
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
π¬π§π¬π§ unfortunately, searches on this forum only go back a short time. The thread was βDash pcb-ectomyβ (by Rog in Somerset) If you stick that in a search engine it should bring it up.
1972 750 βComDomβ sprinter 1958 Triton 650 1992 Triumph Trophy 900
Thank you. π
π¬π§π¬π§
For anyone that hasn't found it the long TM thread that Rog initiated starts here. Pretty much all information on his full standard relay based replacement of PCB is there if you sift through. Julian, sad to say the 2006 - 2014 parts book wiring schematics have many errors but even more omissions. I know the fuse box labeling on later chassis loom schematic has fuse box numbering 11 - 20 reversed for example.
