0 members (),
323
64
Topics49,880
Posts837,761
Posts: 6 Likes: 4
Posts: 6 Likes: 4 |
1972 Morgan 4/4 4-seat. 2.1l 2000 Morgan +8 3,9l 2012 Morgan Plus 8 4.8l 2019 M3W 2022 Genesis GV60
2 members like this:
Bunny, PaulV |
Posts: 37,438 Likes: 984
Posts: 37,438 Likes: 984 |
Looks pretty but please explain the theory to me if you can.
Posts: 6 Likes: 4
Posts: 6 Likes: 4 |
On a V-twin with separate exhaust systems, the two cylinders do not operate evenly. Each cylinder generates pressure waves that propagate through the exhaust. A crossover connects both exhaust headers, allowing these pressure waves to support each other.
The main advantages are:
More torque in the low and mid-range RPM band: Thanks to improved use of the pressure waves, the cylinders are scavenged more effectively. This often makes the engine more responsive and flexible.
Smoother engine operation: The pressure pulses balance each other out to some extent, resulting in a smoother-running engine.
Slightly more peak power: Usually only around 1–3%, provided the rest of the exhaust system is also tuned accordingly.
Reduced heat buildup: Depending on the design, the exhaust gas flow is distributed more efficiently.
Changed exhaust note: A matter of personal preference. Sound often becomes fuller and deeper, though sometimes slightly less "harsh."
Lower fuel consumption – an expected reduction of about 1 L/100 km.
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Thank you so much for going to the trouble of explaining this, the benefits seem to make this necessary really.
Is the Siamese exhaust system on parallel twins a sort of halfway house answer to the problem.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Congrats and nice welding!
1 member likes this:
kvdHoff |
Posts: 8,684 Likes: 414
Posts: 8,684 Likes: 414 |
In essence the exhaust pulses of one cylinder aid scavenging of the other. Moto Guzzi V twins had a crossover on the front pipes or via an H section under engine or both.
kvdHoff |
Posts: 8,688 Likes: 495
Posts: 8,688 Likes: 495 |
Looks very nicely thought out for layout and well engineered joints, looks much neater than the KH version
kvdHoff |
Posts: 6 Likes: 4
Posts: 6 Likes: 4 |
What I however need is a new air filter cover. The standard one has its scoop only between 5 and 7pm on teh clock and breathes warm air just on the top from the balancing pipe. So better would be one which is wider open. Any suggestions?
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
I've always wondered why the M3W doesn't have a crossover like almost all V2 engines. So I had one custom-made. Visually, I think it turned out really well, and the results are phenomenal: better torque in the low and mid-range RPMs, smoother engine operation, a fuller, more refined sound, and lower fuel consumption. Some pics: ![[Linked Image]](https://i.postimg.cc/CMsfj71L/Foto-1-max-100-KB.jpg) Great idea and nicely executed! What exhausts are you running? Just wondering if the crossover pipe would have more effect on a car with standard (i.e. restricted) exhausts than it would on a straight-through system. Also, can the crossover pipe be removed without disturbing the headers? What diameter is the crossover tubing? Thanks, Bunny
Andy
