3 members (TBM, piquet, John V6),
238
54
Posts837,251
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Definitely in the category of First World Problems... BUT, I've always found the area around the ignition lock to be a bit tight when putting the standard key in the ignition (of my RHD car). A quick look on eBay found a key blank which is 15mm shorter. Sometimes it's the little things that make a difference! ![[Linked Image]](https://www.tm-img.com/images/2026/07/21/961CDA17-7B1A-4828-818B-269B7EECE400_1_105_c.md.jpeg) For reference, the standard key is 73mm long and the new one is 58mm.
Andy
1 member likes this:
PaulV |
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
I didn't like the oversized key either, so I shortened one... ![[Linked Image]](https://www.tm-img.com/images/2026/07/21/IMG_0119.jpeg)
Steve Late 2012 M3W
2 members like this:
Bunny, Martin W |
I didn't like the oversized key either, so I shortened one... ![[Linked Image]](https://www.tm-img.com/images/2026/07/21/IMG_0119.jpeg) Even better!
Andy
If anyone's interested, THIS EBAY BLANK is the same length as the one that I used.
Andy
Lesson for today: Not all M3Ws are the same! Who knew? Upon inspecting another M3W, who's owner insisted that he's never had a problem inserting his key, it was apparent that his ignition barrel is mounted slightly more rearwards than mine is. Therefore it's not so tucked away and he has an easier key approach angle. Some people have all the luck!
Andy
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Lesson for today: Not all M3Ws are the same! Who knew? Upon inspecting another M3W, who's owner insisted that he's never had a problem inserting his key, it was apparent that his ignition barrel is mounted slightly more rearwards than mine is. Therefore it's not so tucked away and he has an easier key approach angle. Some people have all the luck! So much for “They are all like that sir!”
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
And even the "standard" key is not as standard as it should be with some being shorter than others.... as standard.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
They're all like that Sir!
