Posts837,249
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
Thanks Rog, that looks just what I need. Is the bellhousing plate a commercial one or a self made? And just how difficult is it to get the nuts on the countersunk bolts on the rear mount? Doesn't look as if there is room to get a finger in there!
Posts: 1,042 Likes: 148
Posts: 1,042 Likes: 148 |
I took a more surgical approach  Bellhousing before ![[Linked Image]](https://i.ibb.co/2P4fBT9/Screenshot-20240506-205713-Whats-App.jpg) Bellhousing after ![[Linked Image]](https://i.ibb.co/9hMvjrk/IMG-20240508-WA0017.jpg) Crossmember before ![[Linked Image]](https://i.ibb.co/x2S0qKF/IMG-20240420-WA0004.jpg) Crossmember during ![[Linked Image]](https://i.ibb.co/j5G21Gs/IMG-20240508-WA0011.jpg) ![[Linked Image]](https://i.ibb.co/MGtb0CM/IMG-20240508-WA0013.jpg) Crossmember after ![[Linked Image]](https://i.ibb.co/3dgZzjt/IMG-20240508-WA0012.jpg) ![[Linked Image]](https://i.ibb.co/CPGy1CT/Screenshot-20240508-172210-Whats-App.jpg) Job done
Posts: 318 Likes: 5
All very nice. I don't do metalwork and I don't have a hoist unfortunately. It'll be axle stands and on my back for a while!!
The gearbox mount is now very much Monty's low point. ![[Linked Image]](https://i.ibb.co/6cJy53S5/Gearbox-mount-nuts.jpg) I've slowly been using the road surface to machine down the two protruding 'sacrificial' nuts as arrowed above  The tyre idea is all well and good for most, however, my plan to go up from Monty's existing 185/65 tyres to 195/65s will actually only give me 2mm of additional ground clearance. Changing my already machined down gearbox mount nuts to countersunk alen bolts adds a further 8mm, so a total ground clearance improvement of 10mm. While 10mm doesn't sound like much, as others have suggested it's actually a game changer; however, I also have a pair of these to fit..... ![[Linked Image]](https://i.ibb.co/C5z9210V/YVb5Xd27.jpg) Let's call them 35mm lower damper eyelet extenders, but with a 90 degree twist  To keep it all swinging with the natural rearward axle movement, Monty's rear Bilstein top mounts it will also get these eye to pin converters..... ![[Linked Image]](https://i.ibb.co/8DY096fB/procomp-eye-pin-adapters-gl1134-gwyn-lewis-4x4-02.jpg) The new setup should completely resolve any residual ground clearance concerns, while at the same time removing the dreadful binding/twisting loads that cause this sort of thing..... ![[Linked Image]](https://i.ibb.co/7NNQDdMC/Mqa-Lx3t-P.jpg) ![[Linked Image]](https://i.ibb.co/3mx568gs/b-MNFBn-X8.jpg) ![[Linked Image]](https://i.ibb.co/RpDH4j5d/F86-q-DRE.jpg)
Posts: 5,432 Likes: 465
Posts: 5,432 Likes: 465 |
Interesting, I had thought that the shocks were acting as involuntary bump stops by reaching the end of their travel before the suspension did....?
Posts: 8,656 Likes: 487
Posts: 8,656 Likes: 487 |
Interesting, I had thought that the shocks were acting as involuntary bump stops by reaching the end of their travel before the suspension did....? Be careful if you've got AVO's, if they bottom out it will break the internals and they WILL leak
Posts: 8,655 Likes: 407
Posts: 8,655 Likes: 407 |
My front AVO's as supplied by Cain did have internal poly bump stops I found.
My front AVO's as supplied by Cain did have internal poly bump stops I found. Yes, fair credit to Cain as I think it was one of his re-spec upgrades to the new versions
Interesting, I had thought that the shocks were acting as involuntary bump stops by reaching the end of their travel before the suspension did....? A good set of telescopic dampers like my Bilsteins should have a bump stop on the rod, but these are really there to protect the damper internals. ![[Linked Image]](https://i.ibb.co/v6GnVc4D/Screenshot-20251112-203816-Gallery.jpg) I've actually temporarily replaced my original Bilstein ones shown below. ![[Linked Image]](https://i.ibb.co/r2P9nSD9/IMG-20240529-WA0017-1.jpg) With a shorter set from Protech, I did this for more damper compression stroke which worked really well.. ![[Linked Image]](https://i.ibb.co/7dfqt56S/IMG-20251025-WA0045.jpg) The true bumpstops on a Morgan are simply hard rubber blocks and work on the rebound, in my opinion they are nasty things. ![[Linked Image]](https://i.ibb.co/kVDGrdfW/20251122-160655.jpg) I replaced them with a set of Triumph TR3 axle mounted bump stops, these were originally made from rubber and you can still buy them in rubber. ![[Linked Image]](https://i.ibb.co/Gfs52WNL/20251122-160655-4.jpg) However, I went for the upgraded polyurethane type. ![[Linked Image]](https://i.ibb.co/RGPQC3Ls/20251112-203021.jpg) They gave me a bit more rebound stroke, and work great as part of my package of other improvements
