Topics49,860
Posts837,488
Posts: 126 Likes: 6
Posts: 126 Likes: 6 |
Hi all, I have a 2005 Roadster with the easy up hood. The hood fabric in the center of the hood is loose and billows upward at speed. I have adjusted both the sides of the hood frame and rear securing pins to try to tighten things up, but was only able to achieve a minimal improvement. Should I be lengthening the sides of the frame, or shortening them? I did adjust the pins at the rear to provide more tension. Any tips on correcting this are appreciated.
John Linkosky
1995 4/4 2005 Roadster 2016 3W Superdry Edition
Posts: 1,984 Likes: 103
Posts: 1,984 Likes: 103 |
My Roadster is four years newer than yours but the hood may be the same design ? Mine does biillow slightly with both the hood and sidescreens in place, but only over 60-70mph. At what speed do you encounter the billowing ? The hood fabric should be fairly taut and it sounds as if you have tried many adjustments, have you looked at the "slider" on the frame which gives about a one inch fore-aft adjustment ? (You may need to shorten the short arm of an Allen key to gain access). ![[Linked Image]](https://www.tm-img.com/images/2026/08/31/Hood-slider-passenger-side.jpg) ![[Linked Image]](https://www.tm-img.com/images/2026/08/31/Hood-surface-crop-to-show-tautness.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 8,672 Likes: 408
Posts: 8,672 Likes: 408 |
Old thread on the adjustment of hood via sliding rails here, noting the caveats of adjustment. ETA: Apologies just noticed you started that thread as well. No luck last time John?
Posts: 5,587 Likes: 603
Posts: 5,587 Likes: 603 |
linklaw ... you don't have a cat do you? .... mine was obsessed with sleeping on the hood .... the perfect cat hammock ... and it took that shape after a while! 🙂
