10 members (Graham, G4FUJ, John V6, RJW, AZJowett, RedThree, Alistair, JMcL, Orjan, Scrambledsignals, Luddite), 97 guests, and 44 robots.
+8Rich 100
John V6 66
Luddite 56
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
Factory meet
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,937
Posts838,576
greenteagod
Page 167 of 168 1 2 165 166 167 168
Good advice Richard. Just dread trying to remove the strips.
Robin
2005 Plus 4
1976 Plus 8 prev
1972 4/4 prev
1959 Series 2 prev
Originally Posted by GrumpyPa
Replaced the throttle cable today. The other day I was just checking over and noticed the cable at the carb end had a couple of whiskers. I looked a bit closer and found that the cable was virtually broken. Fortunately the car was in the garage, I dread to think what would have happened if it had broken when out driving.Thanks to BHM a new one was in the post the following morning. Took the opportunity to remove the pedal and give it a thorough clean.
I had exactly the same thing a couple of years back. On closer inspection, I also found strands broken at the bulkhead end as well. Having seen the horrendous price of a new Morgan one, I resorted to Carbuilder Solutions and purchased their cable repair kit in a tin (CRKIT). That comes with two long inners of different diameters and a good selection of universal nipples, at a current cost of just £12. It’s worth keeping one in the car, as it is very compact.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Morning Strathavon, Yep, rubber strips are a doddle to remove. When out using a very narrow wire channel brush clean up the rusted screw heads, they clean remarkably easily and you'll wonder how so much rusting has such little effect on them!
On refit I use red rubber grease for 2" on top of the cleaned heads and silicone grease on the rest of the channel as if you use a grease product on the whole channel the rubber tends to pop out. The silicone will wash out and you only really need it to ease the fitting of the rubber. When all back together run ACF-50 under all the channel between it and the wing. Let it sit overnight then wipe away residue in the morning. As Richard said, that's where the corrosion from water ingress originates. Most things on a Mog require finding the cause and rectifying it rather than treating the effect it caused.
1 member likes this: Strathaven
Sewin, that sounds encouraging and worth trying. The bumps on my rubbers are not really significant tbh but I never ever thought that something needed done. Each of the three previous Mogs had the same issue!
Robin
2005 Plus 4
1976 Plus 8 prev
1972 4/4 prev
1959 Series 2 prev
The problem is, if you ignore the signs of corrosion (the bumps) it can get quite nasty under there
2 members like this: Strathaven, SteveT
took it to the seaside for fish and chips!
2 members like this: Strathaven, Luddite
Doesn't get better than that grumpy! Fish and chips and a Morgan......Mmmmm!
1 member likes this: Grumpy2
The other tip, which I’m sure has been covered, is when refitting the rubber strips into the channel is to put the ends in first and work towards the middle. I used a really blunt old flat screwdriver and lube it and do a small bit at a time.
Oh and I put masking tape along the length of the strips before starting to remove the rubbers, The rusty bits that fall out are sharp and paintwork easily damaged.
2008 4/4 1.8 Duratec
Fitted a new silicon boot to the steering rack. Decided to remove it completely to make sure removing the clips didn’t cause damage and that the spacer washers wound up in the right place etc etc. Other than that it seemed reasonably straight forward.
Simon
2002 4/4
2026 Mini Cooper
This weekend we are doing a trip around the countryside. I had heard a slight squeak in the front end the other day. I pulled the hubs on both sides and inspected everything. I didn't have new seals, so I only repacked the small bearings, but everything looked fine. I put it back together and adjusted the crown nuts. Re-greased the sliding pillars. And greased the rear axles.
On the test drive, no more squeak. Now we just have to watch the weather. There's a Nor'easter heading our way. Hoping it stays to the south.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
