2 members (DavidR, linklaw), 103 guests, and 20 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
Page 169 of 169 1 2 167 168 169
Really when it comes to the rear shocks, imho is that they fit your car correctly. (All Morgans are different sir) they need to be “circa” 8.5 in at full compression & 12 in at full extension. You can get a good idea of what your car needs using a tape measure & some trigonometry. (Posted on TM some time ago)
Morgans have so little movement available, in that the car either rides along on the shocks internal stops or hangs on the shock at full extension. Getting ones that fit to prevent that is imho a must.
Originally Posted by sospan
Spokes were "pinged" and all seemed ok, even the one where the tear is. Tyreis new with only 300 miles. No clues as to why it happened. Outside chance of a bump during new tyre fitting?
Time will tell.
New tyre only 300 miles ? I assume recently fitted then ?
If so the tyre monkey has caught the inner seal with the lever or the nasty air tool bead breaker, I've had the same & they don't admit catching it - you just find a slow puncture a few days later banghead
You may struggle to get a good seal from a patch-up as silicone does not stick well to existing, I had to grind out all the split area
Spot on I think Cooperman, my thoughts exactly and happens when removing a tyre. You can bodge it but send it to NWS and they will do it properly
