2 members (JoeSpeetjens, Laurens), 161 guests, and 71 robots.
+8Rich 76
Topics49,860
Posts837,520
Jonny72
Page 4 of 4 1 2 3 4
1955er #85109 12/03/12 09:32 PM
1955er Offline OP
Identical except for an additional small spade lug connector on opposite side which connects with the ballast resistor next to the coil. I suspect this one is for a non ballast ignition system and mine is with ballast.
I'm now fairly certain the part no. is 76795 or 76789 would also do.
So much help from everyone.......what would I do without TM!
cheers Neil.
1975 4/4 4 seater, cream over blue; Q3 Quattro; Bicycle; Walking poles.
1955er #85117 13/03/12 05:36 AM
1955er Offline OP
Thanks to everyone for all the suggestions. notworthy
Got the part this arvo from a local auto electrical place and fitted it. All is working well.............at the moment! waiting
However, I've popped the mutimeter into the car for now and if it should happen again I can do a bit of sleuthing! sherlock as it could just still be the starter at fault.
Happy drive to one and all.
cheers Neil.
1955er #85130 13/03/12 07:55 AM
Before you replace the solenoid I would check with a multimeter that it is being powered.
1955er Offline OP
Yes John, everything checked out OK.....no unusual voltage drops, no unexpected increased reistances, all connections checked and cleaned and power going to solenoid.
The RACV guy did it all originally but it didn't hurt to check!! nono
As I mentioned in a previous post, the multimeter will accompany me for a while! drive
cheers Neil.
1955er #85171 13/03/12 04:35 PM
I had a problem like this on my 76 4/4. There was a connector under the dash near the washer which ad over time got wet and therefore corroded. The problem was exactly like yours and attending to this connector solved it. Maybe??????????
meabh #85206 13/03/12 09:11 PM
1955er Offline OP
Now that is an interesting one!!.....................I'll certainly follow that up. Thanks. notworthy
cheers Neil.
Page 4 of 4 1 2 3 4
