2 members (ScotiaSteve, Ian B),
354
105
Topics49,860
Posts837,484
Posts: 463 |
I'm thinking about changing my current exhaust, I’d like it to make a little more noise. At present I have standard side exits, I’ve re-read a couple of old threads on aftermarket units, but couldn’t find anything on the Morgan double side exit, as fitted to the SuperSports. I know some have had this conversion, but to S4’s, mines an S3, any thoughts/opinions would be appreciated – Aeroman, Boshly, Shooter Cheers Matt
Posts: 7,363 |
I did change the box on the side exits on my S3 Matt, but if I was going to change now I would definitely go for the Aero SS twin-pipes. I'm sure that Boshers will be along shortly as he has had the twin-pipe conversion done at the factory on his S4. Cheers Brian P.S. Hope to see you as usual on the way to LMC!
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 463 |
Thanks Brian, TBH your to blame, I can still hear your Supersport as it overtook us on route to Le Mans 2010  O Yes I'll be there
Posts: 7,363 |
QED Matt. I guess you need to speak to the Works about getting them fitted in time for this year's trip! Brian
Brian
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
I might have to follow another member on here and buy a second Aero so I can have this conversion done, as I think it would be a capital offence to molest the Aeromax in this way, but I do love the sound!
-------------- Maxxed out!
Posts: 203 |
Is the SS exhaust a complete new system or just the end pipes compared to the S3/S4 ?
Posts: 169 |
Where would I get an S1 converted to side pipes and how much are they likely to charge?
Thanks Andrew
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
My S1 has a sports exhaust but it still doesn't make enough noise.
Thinking about getting a system made
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 203 |
I love the Aero but one thing is it's a little quite for a V8.
Same thing when I had a Griffith , took it down to Furnhurst TVR and for a modification to the baffles with no exhaust change it sounded great.
Posts: 2,825 |
I was quoted 2-3k for an S1 sidepipe conversion by the factory. Very few S1s (though all GTNs) had them. I believe it's not so simple due to limited space given The narrower body shape.
That was some time ago - there are unlikely to be many off the shelf bits around to do this for an S1 these days too..
