7 members (JohnHarris, Whizjet, Wouter, B3MOG, bmgermany, John Winn, Graham, G4FUJ), 158 guests, and 37 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
#87435 06/04/12 04:12 PM
Just coming up to 10,000 miles (2009 Plus 4 Duratec) and want to service the car. Does anyone have the 'annual' service schedule so that I can pass it to my local garage to complete. I am not proficient to do it myself and I have a 110 mile round trip to go to a Morgan dealer.
Thanks
Tony
Try Go Mog though how applicable it is to a 2009 car I am not sure
John V6 #87438 06/04/12 04:36 PM
The engine side of things would be covered by something like a Ford Focus, so your dealer shouldn't have a problem there. For the rest of the car it's pretty straightforward, grease everything that's got a nipple (front suspension and propshaft), oil everything that should move (including the rear suspension leaves) and tighten up everything that shouldn't, change the diff oil, check and adjust the brakes, give it a thorough clean and check over. Morgans are pretty simple cars and any garage with some experienced proper mechanics would know what to do.
Hamwich #87439 06/04/12 04:54 PM
Now I am concerned.....how often should the differential oil be changed? Any idea what oil to use? Any guidance how to do it..
Keith
minikeefy #87440 06/04/12 05:11 PM
Keith
In my Plus 4 handbook it states the back axle oil should be changed every 5000 miles using a Hypoid 90 oil. You will need one litre of oil.
I hope this helps.
David
1997 Plus 4, Metalic Blue.
2000 Toyota Yaris. (The Tardis)
Oldbill #87443 06/04/12 05:32 PM
The only other thing to be aware of is that the diff oil needs to be to GL-4 specification. GL-5 oils contain additives which can attack yellow metal (eg brass).
Changing the stuff is dead easy, there's a drain plug at the bottom and a level plug in the side. Again, any competent garage mechanic will know what to do.
Hamwich #87463 06/04/12 07:05 PM
For anyone with a Limited Slip Differential, be particularly careful to put in the correct oil -- mine seems to have had the wrong stuff from the factory and I had a 8 month search for what appeared to be sticking brakes, but really was sticking diff due to the wrong oil!!!!!!
The right stuff for a 2009 plus4 is Castrol SAF-XA for others CHECK!!!!!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Robbie #87467 06/04/12 07:16 PM
That's LSD oil, an open diff will use ordinary EP oil.
ivanford #87469 06/04/12 07:32 PM
I have a Quaife ATB helical gear LSD diff in my axle, and I was concerned to ensure I used the right oil, so I contacted them direct to ask the correct grade and type of oil to use. The reply I got was interesting:
"...One of the big benefits of the unit is that there is no friction
affecting performance and units can run in any lubricant, some of the
sealed units run in grease others automatic transmission fluid. The best
advice is to use whatever oil you feel best suits the crown wheel and
pinion and serevice as you would a normal unit."
So I guess it's the locking plate diffs that are the issue here?
Hamwich #87471 06/04/12 07:47 PM
can someone tell me the best grease to use on the front suspension and the prop shaft. i have used Lithiun high melting point in the past but i do have some graphite grease but do noit know which is the beat to use?
The Car is fast the sky is blue just be safe in what you do
