7 members (Robbie, Burgundymog, Sir Percival, gaston, SteveD, jbk, TalkMorgan), 346 guests, and 54 robots.
+8Rich 92
Topics49,837
Posts837,286
Page 7 of 7 1 2 3 4 5 6 7
AQM Offline
Originally Posted By asbojohn
I had looked at something similar bu the diameters are wrong, I've also thought about mounting a cricket or snooker ball in the end, trouble is nothing obvious works.
Might need to find a metal fabricators and get something turned out of ali
Bummer.
What about getting a tube that goes slightly up and out bend into shape, that has a smaller tube inside to fit into the ends of the chassis tubing (think "beach buggy front en miniature")?
If you do it like that (or similar), you can use a small screw/hex to fasten it in each tube.
le Asbo du Bling
le Asbo du Bling
Originally Posted By 1560
keep that radiator (oil) clear!!!!
Thought that was a heatsink for the charging regulator?
Cheers,
That's certainly what it looks like.
Slowly going green
le Asbo du Bling
le Asbo du Bling
Bummer.
Found these earlier
Cricket balls
Slowly going green
AQM Offline
LOL, how British is that!?
V
V
Help me out, whats it all about a Cricket ball?
Manfred
Try to catch the wind in a M3W
le Asbo du Bling
le Asbo du Bling
If you remove the front number plate holder you are left with 2 ugly looking ends of chassis tube. I've been looking around for decorative items to put on the ends, hence the cricket balls as a suggestion.
Hope this helps.
Did also think about these
Smilie Balls
Slowly going green
V
V
Thanks, I understand it now.
Manfred
A quick update on my latest modifications / changes:
Exhaust heat shields now refinished in black powdercoat. There should be a sufficient air gap from the exhaust pipe to stop the coating from burning. I see on the latest MMC price list that black heat shields are now available as a £200 + vat option.
Removed the naff 'hot' sticker on top of the engine, in fact it had already started to lift on one edge.
Made up a battery tender lead to plug into the accessory socket.
Got my factory paint touch up and tended to a few minor paint stone chips.
I have also bought the MMC outdoor fitted cover.
