Topics49,868
Posts837,640
Posts: 486 |
Hi all
Just started to get that hi pitch metallic cringe of cog not engaging with cog as I go to start, not every time but, need to fix before the flywheel gets mashed.
We are off Thursday to Germany to compete in a rally, so I need a quick starter motor change. Does any one know the part no, so I can hit the local part factor or is it Morgan only ?
Cain
Cain
Wolf Cafe Racer 4/4 Sport
Posts: 12,260 Likes: 319
Posts: 12,260 Likes: 319 |
I'd be amazed if it's not the standard Ford part. If you're going to change it yourself then the easiest course of action might be to take the old one with you when you go to pick up the new one?
Posts: 497 |
Can't you have it repaired, surely it's just the bendix.
Posts: 486 |
Thank you all. As for the action I've take..... none!! It's stopped doing the grouch, yes I know it will fail half way through the rally!
I'm hoping it was just a low battery, have any other mog'ers had a similar experience.
Cain
Posts: 462 |
I'm hoping it was just a low battery, have any other mog'ers had a similar experience. Yes, me a month ago. It was the battery (11 years old).
1967 4/4 1500 Comp. 1935 Super Sports Barrelback
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
I'm hoping it was just a low battery, have any other mog'ers had a similar experience. Yes, me a month ago. It was the battery (11 years old). same here, battery problem, new battery no problem
