11 members (RedThree, Elliot, vincentvg, Graham, G4FUJ, DCH, flyfisher, JMcL, Robbie, ScotiaSteve, Luddite, MATTMOG), 220 guests, and 46 robots.
+8Rich 76
Topics49,863
Posts837,553
#89681 25/04/12 12:34 PM
spongy Offline OP
Ahhh, i've got a flat battery and need to get at it to charge it up. Only i can't get at the battery as it's all sealed up. Any advice out there?
spongy #89686 25/04/12 12:41 PM
Sorry to hear you got a problem.
What vehicle is involved?
Ian
Wirewheel #89691 25/04/12 12:45 PM
On my plus4, The battery is on the left hand side of the vehicle behind the seat under the parcel shelf.
Two ways to get at it. Both involve pulling back the carpets.
The easiest is through the aluminium inspection hole behind the passenger seat.
Or by removing the plywood shelf.
I hope that helps.
Ian
Wirewheel #89720 25/04/12 04:26 PM
Anyone tried the trickle chargers that work through the cigarette lighter? I take it the theory is similar to an optimiser?
Moss #89726 25/04/12 04:38 PM
That works if the socket is live with the ignition off.
Spongy - if your battery is behind the seats you can access either through the aluminium panel behind the nearside seat or by lifting the tool tray out (or blanking panel) over the axle.
Moss #89727 25/04/12 04:39 PM
Hi Moss, I did not over that up as a suggestion, cos although I have bought a CTEK to trickle charge next winter, I have not tried it and don't know for certain that it will charge a totally flat battery (and assuming Spongy's car has a live power socket. With luck he will come on later with more info.
Ian
Wirewheel #89729 25/04/12 04:47 PM
I use a CTEK conditioner through my cigarette lighter socket, I don't know if it'll recover a flat battery but guess it depends on why it's flat ( dead cell?)
Steve L.
1996 Plus 8
N22 MOG
Steve +8 #89738 25/04/12 06:31 PM
E
E
The CTEK will recovery a flat battery.
eddie
I can go buy this CTEK in a ... Halfords? (other outlets are available!) or do I need to order online? I've optimisers here but they need to be attached to the terminals etc - which seems to be hard to access .. from what I read.
Thanks.
DaveW #89749 25/04/12 07:46 PM
Hi Dave,
I think mine probably is ok for this. When I picked up the car the guys mentioned one to me as part of the 'new car' briefing and said they could supply one to me. I forgot all about it until I saw Spongy's post. I should have grabbed one there etc. I'll plug something into it tomorrow and see if it's live. Thanks for the tip.
