4 members (MartO, MJF, mph, Graham, G4FUJ), 173 guests, and 80 robots.
Topics49,848
Posts837,395
DazMog, The Impaler, tlchzj79
#91154 04/05/12 11:33 AM
Hi can anyone let me know where I can obtain a hood cover for a 2002 4 4 it would be fitted to cover the hood bars when they are in the down position.
Les
Les Powell Morgan 4/4
Welcome to the forum Les, have you tried the Morgan Motor Company web site! They are showing one for 209GBP. That's the one for the easy up hood.
For the removable hood, some of the guys on here use a tonneau cover.
Hope that helps.
Ian
Thank you I have the old style hood will try the Tonneau cover.
Les
Maybe an admin can move this into the section for 4 4s as they may be able to help more than in the M3W section
Les
Normally you use the tonneau cover. Fold in the sides and roll from the 'front' edge and reattach the clips on the side so it fits up to the back of the seats. This protects what ever you have in the rear as well.
Hope this is what you want to do.
If not then I am not sure what you are after.
Keith
Phoenix Design.
This should be in the Trad Morgan section... smile
Les
Hi Les
Allon Whites of Cranfield will make you a half tonneau, covers the hood sticks and rear shelf, doesn't foul the seat belts or side screens and doesn't cost a fortune either, £160 ish. I used mine far more than the full tonneau when I had a 4/4.
