7 members (Alistair, Ian Wegg, +8Rich, RichardV6, Jensen1960, ScotiaSteve, moggin),
254
60
Topics49,864
Posts837,581
Posts: 22 |
Can anyone advise is it possible to lift the front end of a 4/4 with a trolley jack used in the centre of the cross member then use axle stands to support.
Les
Les Powell Morgan 4/4
Posts: 22,364 Likes: 353
Posts: 22,364 Likes: 353 |
The front jacking point is the centre of the lower cross tube, which although it looks flimsy, is strong enough. I couldn't bring myself to do this without making a block of wood to spread the load. You can use axle stands at either end.
Posts: 306 |
Yes you can use a trolly jack via the cross member tube to lift your morgan but make sure that the jack cannot slip off the tube. Some jacks have small flat plates to lift the vehicle others are shaped to wrap around the tube. Always use axle stands before getting under the vehicle. I have worked on the front suspension on several morgans this way with great success. I hope this helps. David
1997 Plus 4, Metalic Blue. 2000 Toyota Yaris. (The Tardis)
Posts: 22 |
Thank you very much that's a big help as its all new to me.
Les
Posts: 22 |
Thank you for your advice it all makes life a little less stressful and gives confidence when doing maintenance for the first time.
Les
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Don't forget to chock a back wheel when lifting the front end
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Aaaah. Dave..... even your trolley jack is concours!!!  Bud __________ 2003 - 4/4
Bud 4/4 "Stanley"
Posts: 27,814 Likes: 749
Posts: 27,814 Likes: 749 |
A bit off topic but sitting in the company flat here in sunny Moscow and dscribing what I am looking at one the net my Polish colleague suggests when seeing Dave W's garage an overaland challenge to Moscow.
Having seen the roads today that could be a challenge!
Any takers?
