1 members (Alan Patterson), 182 guests, and 75 robots.
Topics49,848
Posts837,395
DazMog, The Impaler, tlchzj79
#93980 29/05/12 04:46 PM
V
v12 Offline OP
V
I am looking to install aftermarket seats (recaro, corbeau etc) for some longer distance and sporting type driving. Having difficulty finding a good seat that will fit well into my 1972 plus 8. Any recommendations on manufacturer and seat type that fits well? Located in California. Fortunately I have a 29 inch waist so is mostly an issue for fitment in the car rather than me fitting into a seat. Thanks!
1965 GT40
Testarossa
v12 #93982 29/05/12 04:53 PM
Morgan 4/4 Sport Competition
2nd the Rev...probably the only one that will fit anyhow.
I'd recommend the Ali Sparco Pro mouns that go under the seat. You can do a trim job to get them round the rear chassis cross rail. They're the best quality fit and provide the lowest seating position.
http://www.demon-tweeks.co.uk/performanc...eat-mounts-pair
You'll also need to trim the seat edge round the transmission tunnel - just pull back the cover and trim with saw. If you are fitting 2 you'll need to trim the wing section where your shoulders go as the two seats foul each other when fitted.
Get a couple of seat boulsters as well as if you are travelling long distance you'll need the support.
http://www.demon-tweeks.co.uk/performance/seat-accessories/sparco-universal-backrest-cushion
Not strictly true- Mulfab do correctly fitting side mounting Morgan ones that fit the seat as low as possible
http://www.mulfab.co.uk/our-products/7/other-miscellaneous
If you are feeling really adventurous it is also possible to modify the crossmember behind the seats to gain legroom and lose another inch or so of seat height
you should be made aware that modifying the seat in anyway invalidates any manufacturers liability or warranty
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
V
v12 Offline OP
V
Thanks guys. This info rocks as I was just about to give up. I'll post photos of the install. I'll take any other recommendations out there.
1965 GT40
Testarossa
v12 #94058 30/05/12 07:58 AM
I was going to suggest Allon Whites sports seats...but then realised you are over the pond!
Jays #94162 31/05/12 12:04 AM
V
v12 Offline OP
V
Thanks Jay. Any contact info on Allon Whites. I'm game to coordinate shipping if it's feasible. -Vince.
1965 GT40
Testarossa
v12 #94190 31/05/12 09:58 AM
