Topics49,877
Posts837,714
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
I have heard from MK and he WILL make a dash.... However he has yet to see the new Roadster so there is some developmental work to do. That’s good news.
David 2020 Roadster 3.7 Dove Grey.
Posts: 534 |
What's your run-in routine Ian?
Is there much less leg room in the 3.7 Roadster compared to the 3.0 or +4.
I like to start off gently & gradually use bursts of more & more power ( just running it in, Officer!) over a couple of thousand miles or so, avoiding labouring and longer periods at higher revs. It's not so much leg room as foot room! You need to use either your toe or the side of your foot to operate the clutch otherwise your foot hits the trim covering the steering column. Later on, I'll see if the trim can be, er, trimmed? Also, the loud pedal is very low compared with the brake, so you need to lift your foot rather than just moving across. That all sound rather negative, but it's not too bad once you've got used to it. Ian
3.7 Roadster 4" Ruston Procter SD Tractor 1905 Merryweather steam fire engine
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Interesting.... Thanks.
I've got quite big feet and I found the latest Plus 8 (the red factory demonstrator) quite tricky with my hooves. I was pressing several pedals simultaneously and was a little anxious about stopping. If the Roadster is tighter it must be extremely tricky.
Are gay shoes the answer?! I can't see me wearing dinky driving shoes though.
Is there a solution to lack of room on the pedals?
+8 4.8
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
Thanks Shiremog, it is the 2 round head screws in your photo I was looking at. Bob:)
Posts: 534 |
I've never sat in a +8, so can't compare with the Roadster. I've got small feet, so I'd suggest you give the Roadster a try, when one's available. There's nothing that can be done about sideways clearance, that's fixed by the side of the body & the transmission tunnel. It may be possible to increase the toe clearance, which is what I'll look at when I get chance. Ian
Posts: 1,948 |
I've got quite big feet and I found the latest Plus 8 (the red factory demonstrator) quite tricky with my hooves... Is there a solution to lack of room on the pedals?
Well, the new +8 is available with only two pedals (ZF 6sp Auto). So you now have a choice between wearing gay shoes or driving an automatic. Personally I'd take the shoes, in pink, please...
Stuart "There's no skill substitute like cubic inches."
Posts: 163 |
I haven't quite figured how I will use a Morgan, I think high days and holidays only - dry ones. Morgans are best driven; the more miles you do the more you will enjoy it. If it's wet keep the top down, drive a bit faster and keep an umbrella to use at traffic lights. Good luck with it!!!
2008 Plus 4
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
+1  Bud __________ 2003 - 4/4
Bud 4/4 "Stanley"
Posts: 541 |
+1 from me too. Quite right!
Ken in Sweden - SM7CQY Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Posts: 28,905 Likes: 353
Posts: 28,905 Likes: 353 |
So that's +3 then
