2 members (Soleng, Black Adder),
314
52
Topics48,347
Posts813,062
Gone to Porsche Part of the Furniture
Posts: 4,328 |
How about clutch on a 504 pick -up, with fixed prop, full back axle out, bit different to MK2 Cavalier, side plate off the Gear/Box, clutch changed in 40mins, go on Vauxhall
Posts: 99 |
the bloo-- bad suspension on the morgan, at times the rocking motion makes me feel sort of sea sick.
Posts: 5,880 Likes: 20
Posts: 5,880 Likes: 20 |
the auto gearbox on my wife's Smart roadster. 5 second wait before a connection is made. Pity since the rest of the car is excellent.
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
4/4 rear lever arm dampers - the casing does not leave enough room for good spanner fit. One came a bit loose. Trouble is the damper housing gets in the way of an open ended spanner and ring spanners were too fat to fit over the nut. I ended up grinding back an old ring spanner to make it thin enough to fit but not too thin to split. GGGGRRRRR!!! The spanner is now a permanent fixture in my toolroll just in case....
Posts: 2,030 Likes: 10
Sir S1'a'lot Talk Morgan Expert
Posts: 2,030 Likes: 10 |
Ferrari California ....... Everything about it
The ugliest car on the road, a total mis match of lines.
Horrid....truly horrid
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 11,221 Likes: 159
Posts: 11,221 Likes: 159 |
For me the frustrating wait whilst the autobox on my Mercedes responds to the instruction to change from forward to reverse or vice-versa.
If you are executing a U-turn in traffic (it is a large car despite its good turning circle) it seems to take forever to make the transition. My VW was a lot faster in making the change.
Its not 1 - pause - 2, its is more like 1 - - - - pause - - - - 2 getting in and out of parking spaces must put my blood pressure up a couple of notches.
Posts: 1,337 |
Sprite Mk1 bug-eye , bonnet hinges - ended up replacing.
Mini early – already been said – distributor behind front grill so got a soaking each time it was wet. Floor starter button awkward to get to and fix
Posts: 4,328 |
Its not 1 - pause - 2, its is more like 1 - - - - pause - - - - 2 getting in and out of parking spaces must put my blood pressure up a couple of notches. How old is the car, or more to the point the GearBox, as hit done lots of work?
Posts: 4,328 |
the auto gearbox on my wife's Smart roadster. 5 second wait before a connection is made. Pity since the rest of the car is excellent. We have a Smart in the Family, my daughter drives it, i know what you mean, i when driving it tend to just release the pressure of the throttle a little to let the gear change, i find it is better to use manual mode when the Car is first started from cold for app the first 2-3 miles then flick into Auto Mode, see if that helps.
