10 members (CooperMan, Morganmike, DaveW, MJF, Mike D, PaulV, +8Rich, Moggo, sprinty, John Winn), 276 guests, and 146 robots.
+8Rich 75
Topics49,869
Posts837,658
Moggo
Thread Like Summary
JohnPlus8
Total Likes: 2
#779157 06/12/2023 9:00 AM
by JohnPlus8
JohnPlus8
Morning all, would Mulfab be as good as anywhere to look at getting an aluminium radiator for our 2004 plus 8 (in the uk)?
And from anyone that’s done the replacement, is a larger fan also necessary also, or is the original adequate?
It’s just for normal (slightly heavy right foot) UK/European road use.
If the larger fan is recommended then what about the wiring/switchgear for it, can the wiring take the extra current that the larger fan will draw?
Thanks in advance
Liked Replies
#779243 Jun 12th a 08:47 PM
by +8Rich
John, knowing how infrequently my heavy duty fan kicks in I would think the standard fit with the efficiency of the Mulfab will suit your needs tbh.
1 member likes this
#779257 Jun 13th a 12:09 AM
by waikiore
waikiore
I changed to a Mulfab or Sifab cant remember and left the standard big fan on, later 95 ish on Plus 8 have a decent Spal fan from memory so you should not need to change, my fan runs at the lights and when i come home into the garage -but at any speed over 50kph the car runs cooler -even with some track work, i did change to an early opening thermostat to catch the heat rise before it became uncatchable . Thought the fan was on too often till I went to Mog 18 and every Plus 8 coming in to the car park had a fan running , so relaxed about it now, at speed I am probably running too cool for the cats -but they are soon to be removed anyway - (not required here).
1 member likes this
