2 members (Graham, G4FUJ, Alan Patterson), 179 guests, and 57 robots.
Posts837,249
Thread Like Summary
Feierstarter, JohnMat, LightSpeed, RichardV6, WilsonLaidlaw
Total Likes: 8
#782734 08/02/2023 9:24 AM
by SeasideNick
SeasideNick
My Banner Bull is now dea d, so thinking about putting a Lithium battery in my M3W, has anyone any experience of doing this, or not doing this lol ??
Liked Replies
#782771 Aug 2nd a 06:33 PM
by Herrie
Herrie
Originally Posted by Bitsobrits
The concerns about lithium batteries being a fire hazard are dated and more theoretical than actual. The current LiFePO4 type for automotive use are highly stable. I do have a battery disconnect switch which is off when the car is stored, but I've done that on all my hobby cars for the last 40 years. As with most parts, avoid no name brands that are suspiciously low priced.
Strange some people do not read the news papers.
A big car transport vessel is on fire at this moment around the North-Sea. 1 crew member dead and nearly all brought to the Hospital.
When this vessel can not be salved the North of Holland will be in extreme danger for pollution.
2 years ago a car transport vessel sunk south of the Azores including a huge pollution case.
Several ferry companies do not allow electric cars on their vessels anymore.
Both accidents have to do with Lithium Car Batteries, which fire you only get out by dumping the car 72 hours in a container filled with water.
When lithium is not properly charged - the reason for those uncontrolled fires - like with our famous regulators there will be a moment you will regret you bought a Lithium battery.
When CCA - crank-capacity - is the issue.
I have a cheap and simple 40Ah lead-acid AMG - but you can use a smaller one too - when you put a super-capacitor bank parallel to it.
Great extra cranking amps. I have this now for 7 month and it works fantastic especially in wintertime.
Your battery will last 2 times longer and the capacitor bank can be sold by your heirs.
One extra tip : all batteries hate a heated environment - say > 40 C - so take them away from your lube-oil tank.
1 member likes this
#782780 Aug 2nd a 09:09 PM
by Bitsobrits
Bitsobrits
I stand by what I wrote.
While there are several formulations of lithium ion batteries in EVs today (LCA, LCM, etc) most formations focus on energy density (range).
Some hybrids and most of the aftermarket lead acid retrofit batteries use the Lithium Iron Phosphate (LiFePO4 or LFP for short) formulation, as their reduced energy density (range) is less important when you have an onboard charging system.
The presence of iron in the cathode of LiFePO4 batteries yields a more stable chemical structure, less prone to runaway discharge events that leads to fires, i.e. it's a safer design. So if you are really reading the 'newspapers' you would do well to note the battery types involved, and would find that LFP type fires are very rare indeed.
1 member likes this
#782779 Aug 2nd a 08:28 PM
by PaulV
PaulV
The concerns about lithium batteries being a fire hazard are dated and more theoretical than actual. The current LiFePO4 type for automotive use are highly stable. ...
A big car transport vessel is on fire at this moment around the North-Sea. ...
Welcome to TalkMorgan! Car transport ferries seemed to have a lot of accidents - plenty of them are nothing to do with EVs!
Interesting data in this story:
Although these fires do present a real danger, fortunately for us they remain very rare. Data obtained by Air Quality News through a Freedom of Information (FOI) request revealed that in 2019 the London Fire Brigade dealt with just 54 electric vehicle fires compared to 1,898 petrol and diesel fires. Although these fires remain rare, when they do occur, they can be extremely dangerous.
That is old data, but if ~2% of cars are EVs, and 2-3% of vehicle fires were EVs, its only a slightly higher risk... but for a relatively new technology I suppose not unexpected. A counterargument would be ICE vehicles are likely to be much older...
Back to car batteries as opposed to EV... I have a Li-based "battery" (actually a battery+conditioning circuitry) and so far it seems good. I do trickle charge though as the car does seem to leak current / I have not yet fitted an isolator! I think an M3W is more at risk from broken fuel tanks than batteries...
Very neat!
1 member likes this
#782769 Aug 2nd a 05:54 PM
by Bunny
Bunny
Originally Posted by JohnMat
Lithium batteries are everywhere these days, and the media whips up these stories about their danger.
I carry one in my pocket all day, and have no worries about having one in my Morgan. Avoid cheap no-name Chinese junk (e-bikes and scooters mostly fall into this category), and buy from a reputable maker.
Well said. The amount of FUD put out by the media regarding EVs (and their batteries) is astounding. I presume there must be an appetite for it - but that doesn't make it right.
1 member likes this
#783262 Aug 9th a 08:39 PM
by rcmatt
rcmatt
do be sure to use a lithium battery charger. Regular chargers will not work.
1 member likes this
#786007 Sep 21st a 12:04 AM
by Bitsobrits
Bitsobrits
I have LiFePO4 batteries in 3 different cars, including my M3W. No changes made to the charging systems in any of the cars. No issues at all. I do put the batteries on an LiFePO4 charger every few months, mostly to make myself feel better.
1 member likes this
#786019 Sep 21st a 07:13 AM
by PaulV
PaulV
Originally Posted by Feierstarter
If I wanted to replace the standard Lead battery by a Lithium battery, would I have to make any adjustments at the alternator / regulator?
After all, Lithium batteries need different voltage levels than Lead batteries.
Any Lithium-based battery for car use will have some electronics within it to do power management. They are typically designed to behave to the car as if it was a lead acid battery ie 12-14v out, ~14v in for charging, discharge protection etc (although the latter seemed to be missing on the Li-based battery that failed on the Grindelweld trip this year - it apparently discharged to zero and became unchargable - mine emptied after the IoM trip and regulator issue a year ago but recovered fine)...
A big question that is difficult to answer from spec sheets is "how good are the Li-based cells" and "how good is the electrics surrounding them". Like Steve's, my battery is LiFePO4 based (as used in power tools) which is safer than the "Li-ion" LiCoO2 based cells used in mobile phones etc.
1 member likes this
#793767 Jan 13th a 12:54 PM
by RedThree
RedThree
The one I have is still available in the UK. It's a JMT YTX30-FP and there is a description of it and a scary price at M&P and more friendly prices on eBay
1 member likes this
