4 members (nick w, Doug J, Jon G4LJW, mph), 292 guests, and 49 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,356
Christoph
Thread Like Summary
Feierstarter, IanClarkeUSA
Total Likes: 3
by Feierstarter
Feierstarter
When I tried to start my Morgan today, the engine wouldn't start, but there was a rattling noise - like a machine gun.
Does maybe the starter pinion not engage properly?
I tried to move my Morgan a bit so that the teeth of the gears come into a different position, but this didn't help.
(Since it is parked in a duplex garage, I have no room in the front and I can't push it upwards.).
Can you relate to the error description rattling noise instead of starting engine?
And how to solve the problem?
Liked Replies
by Chris99
Chris99
It's likely to be low voltage from the battery, either because the car has not been used for a while or the battery is failing. There is not enough power to spin the starter motor fast enough for the teeth to engage with the flywheel
If you can, try jump starting.
1 member likes this
by RichardV6
Yes charge the battery or fit a new fully charged one.
What is very likely happening is that battery charge and/or capacity has reduced to such a low level that when the starter is operated, the current drain drops battery voltage to such a level the solenoid that piggy backs the starter itself drops out. Current draw is removed and battery volts rise just enough for the start sequence to repeat. This typically happens several times a second hence machine gun sound.
1 member likes this
by rcmatt
rcmatt
do be aware that letting a battery discharge that far (especially if it is glass mat) seriously shortens the life of the battery
1 member likes this
