2 members (Vansrv6, BHV), 295 guests, and 23 robots.
+8Rich 92
Posts837,277
Thread Like Summary
WilsonLaidlaw
Total Likes: 4
#786615 09/29/2023 11:46 AM
by WilsonLaidlaw
WilsonLaidlaw
While my M3W is in its winter storage at a local classic car garage, I am going to get them to change the Crankshaft Position Sensor to one of Andy Warren's ones. I have translated the instructions into French using Ai, gone through it and corrected some of the howling errors, like calling a crankshaft an operating handle etc (Manivelle when it should be Villebrequin). I am also going to get them to replace the brake fluid and bleed the brakes (purger les freins). My question to the forum is what is the best fluid? DOT 4 or purple DOT 5 silicone fluid? I would guess DOT4 but not sure.
Wilson
Liked Replies
#786618 Sep 29th a 12:30 PM
by RedThree
RedThree
DOT 4 is ideal.
DOT 5.1 is also very good but definitely not the silicone DOT 5.
The silicone fluid doesn't mix well with normal fluids and would almost certainly rot at least some of the seals in the system.
1 member likes this
#786620 Sep 29th a 01:00 PM
by AnotherBelgian
AnotherBelgian
Dot 5 is not compatible with Dot 4. It will destroy your brakes.
Even in my race cars I used DOT 4. No need to grab 5.1.
1 member likes this
#798932 Apr 14th a 04:36 PM
by RedThree
RedThree
Originally Posted by WilsonLaidlaw
Just thinking about servicing for when I get back to France early next month, am I correct in assuming that as the tappets are hydraulic, there is no requirement to set valve clearances.
Wilson
Yes, nothing needs done to the valves.
1 member likes this
#798933 Apr 14th a 04:37 PM
by planenut
planenut
You are correct, they are hydraulic tappets. If you have roller rockers there is a preset procedure, other than that no tappet adjustment.
1 member likes this
