So, I found a cheap 4 way bypass online.
https://www.amazon.co.uk/dp/B07V45J99R
I liked this one as it completely bypasses the heater, the ones for Taxi's are only 3 way and leaves the possibility that hot water can leak back into heater from the outlet, they are Brass though which is good. I don't like that mine is plastic but thought it should be ok as a prototype and if it works I would look for something more robust.
Diagrams show how it works, link provided by Gambalunga.
It comes with a Vacuum actuator, which I didn't want, but it is easily removed, see picture. It should also be pretty simple to make up a bracket to fit a Bowden cable, solenoid or other actuator in the future. The Lever in the middle isn't spring loaded so can easily be switched On/Off by hand.
It fits between the back of the engine and the heater box, I was going to attach it to the heater box but couldn't find any diagrams of the inside of the box so refrained from drilling/screwing anything into it.
It is simply suspended with 4x cooling pipes clamped to it and feels secure, so we'll see how it goes.
This picture is from is from low down on the offside and shows the pipe from the engine to the Bottom of the Bypass. This is the easiest access for your arm to get to it.
This picture is from above with the heater box to the left, the engine is to the right. It shows the new hose from the Bypass looping round underneath the bypass.
This picture is from the Nearside and shows on the right the 2x hoses from the bypass to the heater box.
Fitting
After draining some fluid from the system, I
- Removed the big Air Intake pipe between the Filter and the Throttle Housing.
- Cut the pipe running from the back of the engine to the heater box roughly in half and fitted the ends to the bottom left and lower right.
○ I purchased a brass straight through connector in case I want to put it back together.
○ NB the pipe I cut has a metal Spring in the end where it bends back on itself, it pulls out easily. I trimmed it and replaced it before fitting the Bypass.
- Simply turn round the heater exit hose so it goes to the top right of the Bypass instead of the T piece in front of the Expansion tank.
- Run a new piece of hose from the higher left port doubling back to the T.
- Replace Fluid and Air Intake Pipe.
So far have just ensured I have no leaks and it works, ie the heater inlet pipe does not get Hot with the Bypass On, but does get Hot with it Off.
The Inlet pipe does go up in temp a little! Could be a leak from the valve letting small amount of water through or just the heat from the engine bay, Have to let the system cool down now so will continue the Air Temp test when all is cooled again and post results here.
https://www.talkmorgan.com/ubbthreads.php/topics/793193/4-gdi-air-temps
Switching the Bypass On/Off means feeding a hand between the Pipes and Engine, which get Hot, so picking a state before starting up is a good idea. If the Bypass stays I'll be looking to fit some sort of remote actuator.
