3 members (Vansrv6, Montegue, TBM), 262 guests, and 35 robots.
+8Rich 93
Posts837,277
Thread Like Summary
BertL, Graham, G4FUJ
Total Likes: 2
#797429 03/13/2024 7:38 PM
by stumog
stumog
[b][/b] Could one of you kind Morgan people please tell me how to download a phot on this web site, I have something to sell
Liked Replies
#800367 May 14th a 08:47 AM
by Image Library
Image Library
Originally Posted by Image Library
An important note:
If you use an image stored on an image hosting service as an avatar you must use a direct URLfor the image, not embed codes.
You can not currently use an image with a .jpeg extension because the forum software does not recognise the 4 letter extension even though the image format is the same as .jpg.
Your image must be .JPG, .PNG, or .GIF and cannot exceed 100x100 pixels.
The tm-img.com hosting service used by many members of the forum currently converts all .jpg extensions to .jpeg which presents a problem only for the use of images for an avatar, but is not a problem for images embedded using BBCode embedding tags.
For the time being new avatars stored on tm-img.com should be converted to .png or .gif using image editing software before uploading. Images uploaded to tm-img.com before January 2023 are not affected.
The TM Image Library tm-img.com is not part of the Talk Morgan forum but was set up by members for the use of Talk Morgan forum members following a debacle with a then popular image hosting site.
Update.
tm-img.com uses the Chevereto image hosting software. Some months ago the developer decided that all images with the .JPG extension should be converted to the .JPEG extension. The two types are identical and it is only the naming convention for the extension that differs.
This caused problems for some sites, including those running on UBB.threads as used by Talk Morgan. It did not cause a problem with embedded images but did cause a problem for images used for an avatar on UBB.threads (Talk Morgan) which must be must be .JPG, .PNG, or .GIF
Following my request the developer has now modified the software so that .JPG files uploaded to tm-img.com now retain the original extension.
If you have a file that uses the .JPEG extension (some cameras and Apple), and you want to use it as an avatar, simply change the extension to .JPG
This is not necessary if the image is the be embedded in a post.
Contact me for any further clarification.
2 members like this
