1 members (Morganmike), 148 guests, and 57 robots.
+8Rich 94
Posts837,276
Thread Like Summary
PaulM3W, PaulV
Total Likes: 3
#805335 08/11/2024 3:10 PM
by Alan Culpitt
Alan Culpitt
I've been completely obsessed with 3 Wheelers since my wife got me a days hire of one for my birthday years ago. Trouble is they are out of my price range.
then this one came along.
It doesnt seem to have many additions and I understand the earlier versions need the updates to ride properly. I'm a reasonably competent amateur mechanic so I'm thinking I could do the updates myself.
Krazy horse are offering one for another £4k that looks nice and has had all the mods, done by professionals
Im thinking the one on ebay is the best bet
Liked Replies
#805343 Aug 11th a 05:19 PM
by Rog G
Rog G
Looking at the photos it hasn’t had even the most basic upgrades, it doesn’t have the bolt in triangulated chassis brace behind the engine, it is still the original straight bolted in brace, it doesn’t have the “comfort kit” steering kit fitted nor the engine cooling fan. The rectifier is in its original position which caused early failures it was moved on later cars.
I suspect therefore it is as it left the factory and still has the original Harley style compensator which will need upgrading to the Centa version and the Aluminium rear sprocket which needs changing to a steel one.
The cost of these parts alone could be approaching £4k, and the compensator change is an engine out job. I would go for the Krazy Horse one.
Low mileage isn’t everything they get better with use and get all the bugs ironed out, I am on my second and have done a total of 60,000 miles.
2 members like this
#805339 Aug 11th a 04:01 PM
by Chris99
Chris99
If you haven't already do read Bunny's excellent buyers guide https://www.mtwc.co.uk/wp-content/uploads/2020/07/Final-150.pdf
For a 2012 you need to check/budget for the following:
Has the chassis got the factory/dealer fitted bolt in front chassis brace?
Does it have the Centa compensator or is it still soon the original Harley type. If Harley you need to change it for the Centa compensator and whilst you're at it have the Bleazey conversion done so you can access and change the rubber transmission rollers. Budget say £1-3k for this.
Has it had a steel rear drive sprocket retrofitted? If it's still the original alloy sprocket that needs changing - probably anything from £500 - £1k
Check the date codes on all 3 tyres, they are probably the originals which are over 12 years old and need changing regardless of tread depth. Put Blockley tyres on the front and I'd recommend a Michelin Cross Climate on the rear.
Budget for a full service with engine and bevel box oil changes and a brake fluid change.
If it hasn't had the "Comfort Steering" mod done then I'd highly recommend you get this done. As standard the car is prone to bump steer.
I'd also be replacing the fuel pump with the Walbro and getting a new battery (see the Alternative Parts list for recommendations, I use the Yuasa UR-1 which is £55 from Halfords.
Don't let the list put you off and contact Craig at M3WServices for a better idea of the costs of the various upgrades. He may also know of otehr alternatives on the market.
The Krazy Horse link didn't work for me but I assume it's this one https://krazyhorse.co.uk/collections/current-car-stock/products/morgan-3-wheeler-sport-grey-1
Personally I'd prefer the KH one as it has the essential mods plus some nice to have options eg LED headlights. KH continue to specialise and support the M3W so you have the security of working with a dealer who actually knows about the car.
1 member likes this
