2 members (TBM, Graham, G4FUJ), 330 guests, and 87 robots.
Topics49,847
Posts837,389
Thread Like Summary
Deejay, xc68anc
Total Likes: 2
#809998 10/22/2024 7:48 AM
by xc68anc
xc68anc
Yesterday I removed the frontwheels for a intensive clean.
But when I fit the left frontwheel the wheel was blocked. I think the pistons of the caliper don‘t work. For a check (and clean, and also some „ATE Bremsenfett“) I want to remove the caliper. So far no problem.
But for the correct fitting of the caliper, what‘s the correct torque for the caliper-screws.
Thank you for the help! And allways sorry about my bad english.
Greets René
Liked Replies
#810000 Oct 22nd a 08:08 AM
by Deejay
Deejay
I think it may be that the brake pad has stuck to the disc, particularly if you have used water. I often get this problem if I have been out in the rain and then left the car for a few days.
With the car on all four wheels, try moving it back and forth and you might hear a bang as the pads let go. If successful, you then need to clean up the rusty patch that will be seen on the disc.
1 member likes this
#810039 Oct 22nd a 07:18 PM
by xc68anc
xc68anc
As Doug said,
no fear, the brakepads where only a little „clued“ after the last journey in the wet. Out of the garage and a few miles, problem cured.
Also checked: both fronthubs/ wheelnuts where cold.
Thank you!
Greets René
… but the next question…
1 member likes this
