4 members (AlyMatt, JohnHarris, Bitsobrits, TBM), 263 guests, and 88 robots.
Topics49,847
Posts837,389
#809998 22/10/24 07:48 AM
X
xc68anc Offline OP
X
Yesterday I removed the frontwheels for a intensive clean.
But when I fit the left frontwheel the wheel was blocked. I think the pistons of the caliper don‘t work. For a check (and clean, and also some „ATE Bremsenfett“) I want to remove the caliper. So far no problem.
But for the correct fitting of the caliper, what‘s the correct torque for the caliper-screws.
Thank you for the help! And allways sorry about my bad english.
Greets René
2018 plus4 (sports green)
I think it may be that the brake pad has stuck to the disc, particularly if you have used water. I often get this problem if I have been out in the rain and then left the car for a few days.
With the car on all four wheels, try moving it back and forth and you might hear a bang as the pads let go. If successful, you then need to clean up the rusty patch that will be seen on the disc.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
1 member likes this: xc68anc
X
xc68anc Offline OP
X
That‘s an idea and the first step. But the most times I‘m on the bad sides. You Knie: „The German Angst“ ;-)
Greets René
X
xc68anc Offline OP
X
As Doug said,
no fear, the brakepads where only a little „clued“ after the last journey in the wet. Out of the garage and a few miles, problem cured.
Also checked: both fronthubs/ wheelnuts where cold.
Thank you!
Greets René
… but the next question…
1 member likes this: Deejay
