1 members (Marmota), 336 guests, and 43 robots.
+8Rich 93
Posts837,277
Thread Like Summary
Graham, G4FUJ, Jon G4LJW, OZ 4/4
Total Likes: 6
#819687 03/16/2025 4:52 PM
by Montegue
Montegue
Very poor weld penetration Morgan!
Both sides too irked
Liked Replies
#819716 Mar 17th a 08:59 AM
by Montegue
Montegue
The hoop was then offered up one last time and with the dampers trial fitted, it was then properly squared up before all the final checks were made.
Given the 30mm hoop lift all clearances (rear edges of marine ply inner arches to axle, diff nose to hoop, prop to prop tunnel) were very carefully studied, and before tack welding. The hoop was finally properly mig welded, this time with excellent weld penetration that put Morgan's very poor welds to shame.
The Mulfab 10mm blocks were retained to give a nice 22mm arch gap, however, the 30mm hoop lift now gives far better compression travel, and what people often overlook is the blocks actually add 10mm of rebound travel. The end result being far more rear suspension articulation oveall with nothing hitting, and all of it from full compression to full droop being properly controlled by the excellent quality and firmly damped Bilsteins.
All this with the wheels still nicely centred in the arches.
A big improvement over the original very archy look, and the dreadful off-set axle arrangement shown below sick2
The hoop is now infinitely stronger than it was when Monty left Pickersleigh Road in 2012, and a quick bounce test shows good rear suspension travel, again it also proved nothing hits!
https://www.youtube.com/shorts/jVYEwMCUsj8
Compare this with my friends TVR Chimaera also running Bilstein damping (coil overs), and we can see Monty has perhaps a touch more travel, but is definitely more compliant with both setups exremely well damped exactly as one would expect from Bilstein.
https://www.youtube.com/shorts/PwklTEapWQQ
Job done thumbs
3 members like this
#819861 Mar 18th a 09:24 PM
by CooperMan
I'm not defending the Factory (MMC) but the hoops are bought in
Probably the same Co that made the tubular Three Wheeler chassis with latent cracking issues hide
1 member likes this
#819913 Mar 19th a 06:37 PM
by Hamwich
Hamwich
Originally Posted by DaveW
thats why Rog's progressive assists are so good.
Rog's damper assists work so amazingly well I find it difficult to imagine why the factory never got around to coming up with a production version. Every trad should have them.
1 member likes this
#820003 Mar 21st a 12:41 PM
by Rog
Rog
Pleased you like your assisters chaps thumbs
It always struck me that Trads were peculiar little cars with their axles sat on top of the chassis rather than slung underneath like a normal car. With the axle trapped between the body and chassis there's little scope for extra articulation. So super critical to get everything working just right in those precious few inches of movement, whether you have a 5 link set up or a pair of cart springs. But when everything is optimized and working together, with good quality components the ride can be surprisingly good..... smile
1 member likes this
