0 members (), 254 guests, and 91 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Thread Like Summary
+8Rich, Graham, G4FUJ, Jon G4LJW, MartO, Mauli, TBM
Total Likes: 21
#835282 12/18/2025 7:29 AM
by MartO
MartO
Hello, I have used the forum as research into buying my first Morgan. It has been really helpful. I have now joined and this is my first post.
I have always owned and enjoyed driving a classic British sports car, so I'm familiar with working through 'issues', noises and rattles. Over the years I've developed reasonable DIY mechanical skills and tool kit. But, I prefer to drive, rather than spend days under cars on concrete garage floors! I am recently retired (early!) and aiming to do more weekend trips away with my wife, further afield from my usual 'classic' car runs. Hence, a more modern motor in the classic Morgan bodywork should be the ticket as a 'fun' 2nd car.
So, I am going to see a Plus Six on Saturday. I have negotiated by phone and reached an agreement I'm happy with, subject to my inspection. The car is one of the last P6s made. It is 10 months old and <2,000 miles. It ticks the boxes on spec and colours. I will be able to take it for a test run. I like that it will have just over 2 years factory warranty remaining and the reasonable mileage. It will have the latest brakes, radiator/software version (but I'll get it up to temperature and look for leaks). It is clear of any insurance claim history, but I'll check panel lines and obvious fit issues. Although, I see sidescreen, door and hood gaps are fairly common, but can be improved.
I would welcome any suggestions from forum members please, on particular Morgan / Plus Six things you'd recommend I focus on in my inspection. I'm grateful for any advice.
Many thanks, Martin
Liked Replies
#835424 Dec 19th a 03:33 PM
by MartO
MartO
Here's what the fuss is about (hoping picture post works):
3 members like this
#835505 Dec 20th a 08:11 PM
by MartO
MartO
The deed is done and the eagle has landed... happy3
Left home at 7am, back at 7pm. Misjudged the drive home, I thought about 170 miles 3-4hrs. It was 230 miles, starting in fog. Car is smooth, torquey and beautiful. The standard suspension surprised me. Seems well damped, not nadgery and not wallowing on bends. Happy with that.
There are some things to address.
- Significant wind noise, but I've just found the front left securing clamp was not fastened (to clamp the hood to the top of the screen). That can't have helped.
- The bottom two inches of the rear sidescreen seals on both sides don't tuck under, but flair out, away from the body, leaving daylight. A microfibre cloth sealed it off enough to remain comfortable. Quite a breeze from that area onto my elbow and side.
- Also, the sidescreens don't seal at the top, against the hood. Again, daylight visible, especially in the centre at the top. Draught and noise.
- I thought it came with the lockable compartment at the back of the parcel-shelf. It doesn't. So storing tools and puncture kit will need thought. But a bonus is it has sidescreen covers, which weren't mentioned before.
- Both front bonnet catches are very difficult to release / engage. I will look at that tomorrow to see if adjustment is easy,
- Pairing my phone was simple, but pointless. The stereo is poor and weak. I don't mind that though.
I ended up using my motorbike earplugs and it was then very pleasant at good cruising speeds. I only played a little with Sport, S+ and the paddles.
Huge positives:
- Wonderful looking thing
- The engine will be everything I'll ever need.
- The sports exhaust is very funny.
- Seat comfort is phenomenal. Nearly 5 hours, one stop for fuel and no ill effects.
- At 7/10ths the chassis / handling is good and on cold slippery roads, roadholding was confident.
Everything BMW is taught and powerful. Everything Morgan is quirky, old fashioned or quaint. Characterful. I think this is going to work very well for us. An enjoyable day. 🙂👍
3 members like this
#835428 Dec 19th a 03:57 PM
by JohnHarris
Great colour combination englandwave
2 members like this
#835334 Dec 18th a 04:39 PM
by High Hamster
High Hamster
You'll have a mobile phone with you, I assume. Take a charging cable so that you can keep it topped up, and therefore available if you do need it. The USB port will likely be in the glove box. Be familiar with the dashboard warning symbols in case any appear. The link below is to the MY23 CX cars, but the MY25 cars will likely be 99% the same.
As sospan says, check the oil level once the car has had the run and the engine is up to temperature. At that mileage I would expect it to show 4/4 (full, green).
The fuel could be stale, at the earliest opportunity fill with E5, and I suggest using E5 for the first few fills. E10 should be OK if you are using the car regularly but it is more likely to absorb water and the ethanol / water mix can cause deposits, which you don't want in the fuel system (ask me how I know ...).
1 member likes this
#835302 Dec 18th a 10:27 AM
by sospan
sospan
The CX cars are a definite step up from the trads. I have a 2023 Plus Four from new and driven 19k+ miles.
I had a 2002 Plus8 before that. Yes, you can still get the Morgan " they all do that , sir" little things like draughts and sometimes water leaks.
Overall quality of build is better, comfort better, ride better, power steering etc.
It's a BMW turbo so plenty of capability. A 2l version so the Plus Six has a good bit more to offer. Take your time learning!!! You will be impressed / frightened but it's good to get a fright now and then. I was a manual devotee but chose the auto and it is superb. As with any change of car get used to how it responds. Tuning your right foot is something to do!
I use mine in auto in normal power mode but switch to paddles if I want to. Overtaking? Nudge into Sport for a better response to get the job done . I've tried Sport+ but it's not needed, kickdown in auto is more than enough with Sport mode for that bit extra response if "needed" ( the need is for fun too!).
No dipstick for oil checks!!! Use the built in engine management button press method in the handbook. Remember that the engine must be at running temp so I do mine when arriving home.
MMC sorted a couple of warranty jobs ok. One done at the dealer, another at MMC themselves.
I've not had radiator failures. Regular checks are easy, my middle finger is a perfect dipstick! Only one drip found and that was a simple cure of small tightening of ahose clamp.
Driving range...... tank is smaller than a trad. The rule of thumb is to use 250 miles as a guide. Fill the tank, zero the odometer trip and plan your refill stop. I get 45-50 mpg depending on right foot use. A mate with a Plus Six gets slightly less mpg but not much lower, using the 250 mile guide.
Quite a bit of money to buy but.....
You are only here once.
Enjoy the car.
1 member likes this
#835286 Dec 18th a 08:31 AM
by JohnHarris
The first step in buying a Morgan is recognising you are buying a handbuilt car, with a few areas left for owner improvements eg door seals and like all cars they have their moments., I find with Morgans it's just better to go with the flow,and accept them warts and all for what they are and that is amazingly good fun and can be really enjoyable to drive.
I think the last of the P6s are a great specc'd car, with plenty of power, roomy cabin and enough safety systems eg abs and traction control to keep you on the straight and, bendy path, for times when you can get a little too keen. Others will disagree and not want any potential dilution of the driver input, as they say horse for courses.
One of the nicest aspects of Morgan ownership, is the fellowship of other owners and the clubs and forums, involvement with the dealer network and of course the factory in Malvern, where I get my P4 serviced. My P4 auto is now my daily driver and I wouldn't have it anyother way., except for the few draughts I've yet to fix
Enjoy the test drive, they are amazing cars, the CX chassis is a step change to the trads. and a great driving and touring platform. I'm with you cars are for driving, and they reward you more and generally prove more reliable, the more they are used. . Don't worry about radiators and the like you still have factory warranty................
I hope its a nice sunny day on the test run, so the hood is down and you get to feel all of the sensations of sitting close to the driving axle which is connected directly to the input of your right foot, real seat of the pants stuff. Enjoy,
1 member likes this
#835296 Dec 18th a 09:45 AM
by High Hamster
High Hamster
Martin, good choice! I was originally looking at a Plus Four, but arrived at the Plus Six and haven't regretted it.
You will get draughts coming in through the doors, and maybe some water if it is wet. That's standard for all Morgans, I believe (except perhaps the Supersport). As John says these things can be slowly addressed, and that's part of the attraction.
Check the levels in the coolant expansion tanks (one on each side, you will need to open each bonnet one at a time), the levels tend to settle a little lower than the indicated marks on the tank, but you may need a dipstick to check these; I use a wooden plant support stick. If the tanks are really low or, heaven forbid, empty, then suspect a leak somewhere. I've never had a leak, and I'm now officially out of warranty, but I know MMC will still address the radiator issue under 'warranty' if I have a problem.
Have them demonstrate how the hood goes down and up, and note that the tenax press studs must be loosened before moving the hood frame ... you don't want them pulling out of the bodywork. On my P6, which also had low mileage for its age, the spring clips were a bu**er to get into place because the retaining mechanism was 'dry'. It may need some lubrication to ease the operation. Mine works perfectly now.
If you're buying from a dealer these last issues should have been identified and addressed.
Above all, and again as John says, enjoy the test run.
1 member likes this
#835335 Dec 18th a 04:51 PM
by John V6
I'd check the fluid levels in the two header tanks to be safe plus tyre pressures and that the washer bottle is full of suitably strong screen wash.
Good luck and if you are in the Norfolk / Suffolk area as it seems let me know and I can put you in touch with other Mog owners in FolkMog.
1 member likes this
#835345 Dec 18th a 06:24 PM
by High Hamster
High Hamster
Link to my MY23 manual: MY23 Morgan CX owner's manual
Pages 33 and 34 for the oil level check.
1 member likes this
#835364 Dec 18th a 10:46 PM
by JohnHarris
If its going to be a rain filled return journey home, , check the tightness of the wiper blade arms usually an allen screw. They have on occasion a habit of working themselves lose and the wiper arm coming off the spindle. When I picked mine up, the one wiper arm screw was quite loose. When you get a chance just put a dab of thread locker on them. The wiper blades are not the best, but they do clear the screen
1 member likes this
#835383 Dec 19th a 09:59 AM
by John V6
All are metric.
1 member likes this
#835427 Dec 19th a 03:56 PM
by John V6
Gorgeous looking beast
1 member likes this
#835432 Dec 19th a 04:55 PM
by High Hamster
High Hamster
Very nice. I saw a Plus Four at Williams in a similar paint colour a year ago and really loved it. Theirs had a black interior. I much prefer yours.
Alloro green? And it's a Pinnacle, even better.
1 member likes this
#835469 Dec 20th a 06:47 AM
by TBM
TBM
Good luck - beautiful car - am rather jealous!
1 member likes this
#835548 Dec 21st a 10:48 AM
by John V6
This might help. it is very easy to access the speakers and to fit sound insulation. It also shows you the space behind that rear panel.
http://www.talkmorgan.com/ubbthreads.php/topics/814172/1
1 member likes this
#835544 Dec 21st a 10:31 AM
by JohnHarris
I've yet to investigate further on the Morgan, but it was the case to stop draughts entering the cabin through the door mechanisms etc, that car manufacturers would put a plastic barrier/sheet across the inside of the entire door framework, which was then covered over by door panel.
1 member likes this
